Price check .063 aluminum signs...
FatCat
Customer wanting to use .063 to make some traffic style signs to mount on channel posts. Size is 20" x 28", black HP vinyl applied to front, rounded corners with 3/8" hole centered top and bottom. They will be ordering these regularly, in this same quantity and build, so I want to make sure my price is good from the start.
I'm coming up with $58.59/ea based on 8.
Sound reasonable, or high for these simple signs?
petepaz
are you supplying the post and hardware also?
depending on the cost of the aluminum i would be between $50-65 with out the post and hardware
If they are baked-on-enamel finish and YOU don't have to paint them white...... sounds like a very good price all around.
FatCat
Yes, will cut these out of 4x8 sheets, (pre-painted).
For some reason, just sounded a little high for such a simple sign - didn't want to scare anyone off, lol.
Thanks guys! :smile:
