Price check - replacing sign cabinet faces
Big EZ Signs LLC
Hello all, I'm bidding to replace (4) cabinet sign faces.
Sign #1 is two sided, each face is 72" x 96" pan-faced
Sign #2 is single sided, but made of two 36" x 96" pan-faces laid side-by side.
Pulling a number out of the Signcraft Pricing guide ( I'm using Aluminum faced panels for reference ) I'm coming up with a price of $597 for Sign#1 for an "Intermediate" design, and $462 for Sign#2.
Now big problem: I'm not sure which wholesale manufacturer for pan-faces I should use.
sagesign
You need to find a supplier & check their prices for pan faces. My cost from my supplier is approx. $410 each for a 6x8 & $195 each for 3x8.
Techman
you have no clue. Thats a $5 grand job easy...
If you bid those prices you just posted its time to find another line of work..
That type of non experience low balling is what ruins this profession. Non professionals bidding at a loss. If you drop one panel your in the red.
Doyle
Not sure what local suppliers you have, but I use Wensco for these faces.
As for your prices, yeah....... they are pretty low..... I would charge at LEAST $25/sf for those things which works out to:
Sign 1- $2400 total
Sign 2- $1200 total
Check costs on the faces and give yourself enough wiggle room to destroy one of them and still buy lunch
Big EZ Signs LLC
Techman: I have not actually given the client those prices. That was me trying to come up with a number. I was looking here for some feedback from members.
So...... suggestions on wholesalers for pan-faces?
Techman
Let me point out what I posted. Read above.
But, you just can't buy a panel and put it in. These sizes need lexan plus they need to be fastened in a way not to blow out. ITs not just a matter of sliding them in..
IT looks to me like you are out of your league. Are you qualified to make a PM inspection on the rails? Are you planning to replace the tubes? will you replace the ballast?
Are you goona install them for free?
Big EZ Signs LLC
Ok,
1) Yes, I recognize these faces need Lexan. I wasn't about to trot off to Home Depot and buy a 4'x8' of plexiglass. Since these are pan-faced, I need a reputable wholesaler for them.
2) Tubes and Ballast? I'm getting an electrician for those. That will be his area of expertise, not mine.
3) PM inspection on the "rails"? Don't quite follow you on that one.
4) Install for free? Hell no.
Big EZ Signs LLC
Well this sucks. I started giving her the bid and I got shutdown before I even got to the installation charge. Here's what I quoted:
D/F 96"x72" parking lot sign ( only 10' high ) - $3084 for the faces
S/F roof sign - two 40"x96" faces - $2098 for the faces.
She shut me down, because she said the other sign company quoted here $2000 total for both signs.
I don't know, was I overpriced? Could the other company be manufacturing these in house, instead of ordering them like I did?
beckys
ah,happens all the time-
I had quoted 4 lightboxes a month ago-didnt get it.
guess what?? they look like crap.
Clients are very cheap, especially in this ecomony.
Doyle
That sucks, I don't know how anyone could do that job so cheap, and make money..... If you are comfortable making a minimal profit and not being protected against mishaps, than maybe 2000 would work, but geez, my costs would be between $1300 and $1500, and I would surely want to make more than $500 on the job...... and that is for simple, 1 color graphics, nothing fancy at all.
gators2001
I pay 6.25 s/f for panned faces. I sell them for 15- 17.00 depends on size so with install would have been around 2500.00. 31.00 s/ft for panned faces is extremly high. You may have did I don't know but always check what stuff costs you before you quote from people on here.If you still need a wholesaler on panned faces let me know.
high impact
$3000 to $4000 sounds more like it....depending on artwork, labor, blah, blah, blah
I think you were too high but I think the customer also chose a lowballer.
Doyle
It's really embarrassing when another company comes in at less than HALF of your bid on something like this...... I know, I've been there. They were lowballing and you were slightly overpriced.... Get your ducks in a row and nail it next time. What I do is when I come across a bid on something that I have never done, I will get all of my costs calculated so next time I bid, I can reference my cost sheets and make a quick, confident bid.....
Techman
No way,, they lie. Unless the other one is doing them in house. But I seriously doubt it. The shipping costs plus the panels plus the graphics will be around 2 grand alone.
I would've said,, show me the quote. This has happened to me before myself. They said some other place quoted blah blah. I asked to see the quote. They didn't have one. But when they got one it was another story.
Add in shipping charges, install, graphics and the preparation for install, plus some maintenance on the can. They always need bulbs at least.
blackicefx
color me ignorant, but what is the difference between pan and flex face signs? I haven't done any illuminated signs yet and was just curious. Most monument signs I've lettered are usually sheets already mounted on a solid pillar.
Matthew
BlackIceFX
onesource
2200 for a pair of completed 6x8s
1200 for a pair of 3x8s
Find your local wholesaler
it's only a matter of time before inexperience dips into the pockets, Good luck
