Price for Lettering on Interior Wall
racingstripes
Hi all,
I as hoping to get some help on pricing. I am installing some phrases I cut on an interior textured wall. I am about half way through the job and it is for a repeat/regular customer. The actual amount of vinyl used is around 40 linear feet of intermediate (24" rolls).
Details: There is one large phrase in 10" lettering (20 letters) and the remaining phrases are to be scattered about the wall all in 2" (800+ lettters).
Pricing by the letter and for my estimated time I am came in at $575 but man this is a pain to install and taking longer than expected. Where would you guys be on this?
Thanks in advance. Cheers,
Sean
iSign
I'd be half a job back in time... setting a price before doing any work. Collecting 50% too.
It's hard to say where I'd be from the info provided...
but I usually try to bid jobs based on $100 an hour for all my time selling, cutting, weeding, driving and installing... plus 200% of my material costs.
I admit I settle for less... even down to half that... but I start setting prices based on that shop rate. I can afford to go down, since I have other people do a lot of the work now... and I can't always make top dollar for driving... but I can tell you this... it sounds like a job I would never do for less that $575... even right next door!
I usually need to make at least $5/sq. ft. for cut vinyl... without install.. so I think you need to be closer to $800 no matter what.
imaSIGNr
I wouldn't think any less for sure. Maybe more....I am curious how the intermediate vinyl is working with the textured walls...
stickerhead
Next job like this, I would not use calendar. I've learned thru the years to use cast vinyl for interior walls with a clear application tape (for cut lettering/designs). Calendar takes more time than needed to apply and explains what you said, "this is a pain to install and taking longer than expected"..... I usually start any interior vinyl job at a minimum of $300 if the vinyl is 15 feet or longer. I would have quoted this job for at least $1200.
OldPaint
VINYL AND FLAT LATEX.....dont work.....YOU BEEN WARNED.
textured wall? of what texture???? STUCCO, POPCORN, TROWELED PLASTER?????
i think youre gona loose you butt if you vinyl it........get a SIGN PAINTER or learn how to.......
racingstripes
Hi all,
Thanks for the awesome input as always.
Jill and OP yeah painting would have been easier that what experienced so far on the install, but I am at the point of not turning back. As for the install it is a little painstaking (I know that is like being a little pregnant) but going slow but ok as long as I don't "rip" the premask off.
imaSIGNr, the calendered is working out fine. It is actually adhereing better than I expected. I am using low tack premask and its releasing ok too. After the premask is off I am heating vinyl and rolling over with a padded wall paper roller and this is allowing it to conforming to the relatively smooth plaster texture nicely.
I chunked this job into pieces and left the estimate open, because I told the customer that I have never applied vinyl to this type of wall and wanted to start with a proof of concept.
Thanks again iSign, slipperyfrog, stickerhead, Jill, OP, imaSIGNr for your responses.
Regards,
Sean
imaSIGNr
The calendered vinyl probably will not stay conformed to the texture. Cast would better. If you use the heat gun then take a towel knotted up and beat the vinyl on the wall it will help form to the texture.
