Price Help
splman
Need help with price, over all size is 10' X 10'.
Marlene
what is the exact size of the top sign? What is is made of? Is the background painted or vinyl? Are the letters vinyl with a vinyl outline or vinyl with a Gerber Edge spot color outline or are they painted? Double sided or single sided? The cabinet below, are you buying a pre-made or making it yourself? If it's pre-made, use your regular mark-up plus shipping and assemble cost. What about the poles, are they steel? Presure treating? Cladding? What size are the poles? What mounting brackets are you using? Are you making them or buying them? Did you do the layout? Did you have to scan artwork or load from a disk?
splman
ok
top sign is 5' x 10' alumalite, all lettering and outlines are Oracal 751.
I am making the bottom as well, no pre fab stuff. the polls are 4" x 6" pressure treated. I will make all mounting brackets.
I did the design and layout
Marlene
if you are going to tackle a shaped, illuminated sign box I can only assume that you've made these before. What do you usually charge for a box like this? As far as the reader board goes, you have all that goes into making the box, frame, bulbs, ballast etc. plus faces, tracking and 5" font. Pretty much you'll have componants that you pruchase and mark-up and your labor and materials to make the box. It's kind of hard to help with the price as it's based on what you pay for parts, your mark-ups and your labor rate.
Marlene
A 5' x 10' x .25" Alumalite panel from my supplier is $131.28. I'd mark that up .6, $220.00. I'd would need a pattern to cut the shape, $50.00 and $52.00 in labor to cut it. The vinyl you'll have to price out as I don't usewhat you use. For the reader board, I'd have the $220.00 marked up Alumilite and would get my track from Gemini. A 5" is a custom size so I'd use a 6" Pronto letter $243.00 for 300 letters or 4" $165.00 Gemini prices as suggested retail so this is what I would charge plus shipping cost. The track I would use the Polycarbonate so it won't break. 10' top tracks are $13.00, Dual are $14.00 and bottom are $11.00, again, Gemini prices as suggested so I'd add shipping to this. Add in your hardware and install labor of the track. The poles you'd need to use what you pay for them plus labor to cut tops plus all hardware to assemble. Hope this is of some help to you.
Fred Weiss
(Fred sez resource links are ok if I not promoting the product or selling it myself, keereckt?) Signcraft is a friend to all sign people, me thinks.
The McIltrot's are good guys.
Keereckt Barry. This site is about information, learning, sharing and, hopefully, having fun. The rules are simple enough .... be civil and don't ask for or supply copyrighted materials through this forum. Providing links to help answer questions, including links to logos, clipart and fonts, is encouraged. Promoting your own products is discouraged .... I don't even do it for my own stuff.
:Sleeping:
