Price of Coro Signs for Rodeo
mcentyre
Doing an order of 2'x6' coroplast signs for a rodeo. There are approximately 30 signs and they vary in the number of colors from 1 to 3. Most are 2. The signs are 2'x6' with grommets (not sure if I should put 4 or 6).
I've had to do a little searching for logos and recreating others. What you guys do for pricing on these?
We're thinking around $30 (average).
BTW: For what it's worth, they are charging $250 per sponsor, but are allowing us to put up a sign without charge. There hasn't been any discussion of this being part of the payment. The clients are friends of ours and we do work for a couple of other businesses they operate. I know this stuff shouldn't really affect the pricing, but you know how it goes!
Thanks,
Chris
Flame
Digitally print these suckers, and charge around $30 each if they're ordering that many. grommets should cost them a little more though.... Up to you man. Maybe $0.50 or $1.00 a grommet extra?
Pro Image
I get 120.00 for a 4x8 coro 1 color..........I would at least be at 60.00 each for 2 or more colors..............you can only do 2 per 4x8 sheet so about 60.00 each. As far as the prices I charge go,I tend to be on the low end of the scale you going to hear higher prices than mine...........:thumb:
Jackpine
I would get $50 to $60 for each no less. I don't think this is too high and may even be too lowand I would charge extra for grommets....$.50 or a buck each.
Flame
Ooooops!!!!
Okay, I only saw the coro part and assumed that you meant 18 x 24. Okay Dude, I would charge atleast $60 each for a 2' x 6'. Sorry for confusing things there, I was going too fast. So yeah, atleast $60 and then extra for grommets. Tell them to go ahead and price around if they don't like it, no one else will beat that price and give a quality product.
bob
Assuming you're producing actual professional work, both in design and execution, you people work way too cheap.
Assuming 4mm coroplast, $137.00 per copy if they all are different. $128.30 per each for 30 all the same. You only get two signs out of a full sheet of material.
If the truth be known I'd rather have root canal than produce 30 identical vinyl signs. If they're all the same then send them off to some screen shop somewhere. Lots cheaper.
A far better deal for the client is to produce 2x6, or more better, 3x6 which is a pretty standard rodeo chute gate size, banners. A 2x6 banner goes for $98.75, a 3x6 copy for $134.75.
MAB SIGNS
Since they vary in color it's probably safe to say that most are different so screen printing is most likely out. I do like the banner idea as I don't like coro unless it's stuck on a wire H stake. Curious as to why your coro price is so much more than banner price. Since he wants 2'x6' he can get two from a full sheet plus two 18x24's from the scrap. It just seems like the cost for either material is comparable. You're right, you can get those prices for these and I never like being too cheap.
What about Bob? One of my favorite movies. <smiles>
iSign
Pro Signs & Graphix said:
Chris - Is this rodeo a charity event?
It is now... at $30 per sign :biggrin:
"2-color" is not enough information... "searched out some logos... redrew some others" is not enough information...
is that 1 line of brown... 1 line of black... or 2 lines of brown with a black outline/shadow? Big difference right? one way is a little more labor, the other way is double material (unless you are printing them) I just sold 50 coro 18x24 signs yesterday for $24 ea. (lettering only)
I'd be looking for $75 ea. min PLUS my shop rate for every minute spent doing anything other then basic typing out simple text layouts
Checkers
hehehe, $60 would be straight text, one color on white from me. Since there's design and multiple colors involved, I would be more inclined to go with Bob from Earth's pricing, if not higher.
Charity or not, these people are in the business to make money, just like you. But, the difference between you and them at the price you're quoting is that they're making money while you're working for free.
Checkers
bob
MAB SIGNS said:
... Curious as to why your coro price is so much more than banner price. Since he wants 2'x6' he can get two from a full sheet plus two 18x24's from the scrap. It just seems like the cost for either material is comparable.
A banner is printed, hemmed, and grometed.
A coroplast sign is cutting the substrate to size, loading, cutting, weeding, masking, registering, and applying from 1 to n colors of vinyl.
The coroplast effort is far more labor and material intensive. Hence more expensive.
I seldom make and distinction in pricing for complexity or number of colors. Within reason. I make more on real simple stuff and I make less on real complicated stuff but the vast majority of the work is a couple of colors and a reasonable amount of copy. It averages out and it provides repeat clients with consistency, something in which the seem to set great store.
As far as any leftover scrap substrate, treat it as scrap substrate. The client gets charged for all units of substrate used. In this case for every pair of signs it gets to buy a full sheet of coroplast. As well as a full sheet if there's an odd count singleton. If you can use any scrap that's windfall for you but never factor it into your pricing.
MAB SIGNS
bob said:
A banner is printed, hemmed, and grommets.
So your going to digital print? That works for you but it appears that he doesn't have that option without subbing out. I was going off the idea of a banner from Fedders and applying vinyl vs. vinyl on coro. Two banners is comparable in price to a sheet of coro and a better look. Digital or vinyl I like the idea of banners over coroplast. To me, coroplast is too cheap looking to use for anything other than on an H stake.
As the others stated, get extra for design time on logos.
mcentyre
Thanks for all the replies.
The rodeo is not a charity event. Food vending and parking is going to charity, but the advertiser money is not.
Sorry to be vague with the details on the signs. With thirty different signs, there's a little bit of everything. One is nothing but 3 lines of black text, another has 4 colors with detailed graphics (lots of barbed wire!). We were given an envelope with business cards and website links to work from. That's what I mean by recreating logos and Googling others. We are currently vinyl only and would have had to sub out printing, if we'd gone that route.
The customer specified that they want coroplast and not banners.
The price was not setup first (I know I'll get some flames for that!). They just said to charge what we needed to. We told them the price would vary based on how much design time would be needed.
We're still relatively new and pricing is a constant struggle. We have no desire to be the "low baller" and we're learning to put the correct value on our products. That's the reason I posted here, this forum has been a great help!
Thanks for your input.
If that is the case, charge what is proper AND pay for your own sign. As for the up front negotiations - well let's just hope this is a relative that truly likes you - otherwise it is a gamble.
Checkers
Here's a general idea of how I charge for sponsor signs.
Checkers
iSign
Brian... how much more would 13 oz material cost? Pennies right? I'd be concerned with offering a 3 year warrenty on a 10 oz banner even though your plywood backed installation suggestion is sound. Also, I don't see the logic in every banner customer having to calculate liner feet of hems & the number of grommets to figure their price. If 95% of banner customers will order hems & grommets, just raise the $7/sq. ft. to cover it... keep it simple... & just calculate a savings for the 5% who want unhemmed banners.
WVB
I was thinking the samething 10oz = 3yr warranty? Not in these parts buddy... The difference between 10oz and 13oz banners is very slim. With that type of warranty you should really up it to 13oz min. A little more money but a lot less hassle in the long run.
Coro sign 2x6 = $72 each. For us Coro is priced same as banners $6sqf Plus grommets/stakes if needed...
andy
How long has it taken to do the 30 designs?
How much will the 30 boards cost you?
How long will it take on average to do each board?
What is your shop's hourly rate?
Take one board, say this takes I/2 an hour to design- if your rate is $10 an hour which is way too low- then the design just cost to you $5. The cost of one board is say $5. If it takes and hour to cut, tape weed and apply that's another $10. Add in the costs of the vinyl, tape etc.- call it another $5. Using these figures your cost per board is $25- leaving you $5 profit.
Gross profit for doing 30 signs is $150. The figures I've used are pretty low and don't cover other overhead like electricity, internet access costs and everything else.
If you wanna invest and grow your business the getting the right return for your time is the key.
