Pricing Large Repaint
Jillbeans
I need to come up with a figure to repaint this sign, exactly as-is.
My brother's company will subcontract me to do the painting, which has been specifically requested by their client.
Sign is double-sided, 16' across, and 70' in the air. I'm guessing about 128-130 sq. ft. per side.
My brother will provide the bucket truck.
I figure I will have about $100 in lettering enamel.
Throw in another $50 for cleaning stuff, tape and a drop cloth or two.
I plan to scuff with ScotchBrite pads and clean with isopropyl (sp?) alcohol prior to painting.
I think each side will take me about 7 hours, prep to finish.
Signwriter's pricing guide from 2004 sez $1761/repaint, $455 clean/scuff, $35 trip charge. About $2251. Plus materials.
Also, is the alcohol the best thing to use for cleaning?
I was going to use Ronan rather than 1 Shot due to the fact that both the red and the black 1S have been less than stellar lately.
:thankyou:
Love....Jill
Border
I would think you could add another 4 or 5 benjamins at least, just for the height factor. Those are gonna be 2 LONG days up there if everything goes perfect, and even longer if ya end up having to 2-coat everything after the first coat sucks into the dried up original paint and ends up looking uneven once it's dried. I'm guessing that original paint is pretty much powderized by now. If nothing else, let them know there may be an upcharge once you get up there and get a full grip on what the condition of it is.
Jillbeans
Thanks for the reply.
I think the worst part of the job (besides sunburn) is going to be having to spend two days with my brother.
Any ideas about the isopropyl alcohol cleaning? Don't I need to be using 97% or something? I was going to use wax and grease remover but that seems to soak into things too much.
Jillbeans
No! Thanks for the tip.
I just talked to him (what a crab) and he says the sign is 10' tall rather than my guesstimated 8 feet.
So I will have to get out the calculator again.
skyhigh
I'd consider painting this with a latex. You will probably need to roll a primer coat on first. The latex won't fade & chalk like the 1shot (red). The ronan won't give you better results either. Its not the brand of paint, its the KIND of paint that your less than impressed with.
Jillbeans
I don't think putting latex over a metal sign which has been painted with lettering enamels would be a good idea at all. They held up at least 20 years on this sucka.
Altho most of the "good stuff" has been taken out of lettering enamels.
I can smooth on a nice coat of Ronan, which I have had good luck with.
If I used Latex I would have to use different brushes, etc.
I think even Rustoleum would be better than latex. The latex lettering paint I've used faded really fast. Just sayin'.
S
Sign-Man Signs
Guest
Jill,
This is going to be head ache number one for you.
I would prep the sign by using lacquer thinner to remove and contamination.
I am a big supporter of Rust-o-leum. One it dries quick. About $27.00 dollars a gallon. You can apply with a foam roller and get a good base for lettering. Working in the air, out of a bucket, wind is a major factor.
On a re-paint, personally, I'd use an oil base and stay away form the latex. If it doesn't dry good enough, peeling will occur if you use a transfer tape on your design.
Just my two cents. Hope it helps and GOOD LUCK!
Oh, yea. Brother or not, I'd figure my cost and triple it. You'll know why when you get done.
CES020
Any way to spray it with an automotive grade paint? You could be finished in no time.
7 hours in a bucket, 70' in the air. Got to be some additional cost for that. At least $5 more for a new pair of underpants :biggrin:
k.a.s.
Jill,
I think your price is about right, maybe add a little more in case it takes extra time. And I think Ronan would work fine, thats what I'd use.
Kevin
Jillbeans
Heck I can't remember the name of the latex lettering paint I used.
It is on the tip of my tongue but I can't remember the name brand!
It was when I was pregnant with Justis and had been advised not to use lead-based 1S
(now it would be a non-issue)
They no longer make it, thankfully. It wasn't Ronan's latex line.
Most of it faded in a year.
I will be painting directly as-is, no transfer tape no patterns.
My brother said his company is the one who has to worry about drips, etc.
I will definitely be increasing the estimate. There is no guarantee that either of our companies is getting this job.
Jill....
My first question as always.... are you insured to go that high in the air ?? Not for paint drips or dropping things, but you personally.
So after that..... I think you're too cheap in your pricing. You have to take into consideration the time involved moving the bucket from side to side and back and forth. That's your time while that's being done.
I feel that would be close to a 40 to 45 hour job if done correctly. At that height, you should be charging $125. at least an hour at that height.
After removing all the debris and loose paint with a wire brush... I'd sand with 360 grit sandpaper, not a scotch pad. Clean dust off with damp towels. Rub alcohol over it if you'd like and then again clean it good with plain soap and water and let thoroughly dry. I'd prime any rusty spots with clear anti-rusting prime. Next, paint the whole panel, both sides, white with 1-Shot bulletin.... not blackout. When dried, cut the red in around the white and roller the outer edges in and hand-paint the scrolls back in. Using only one white coat... your whole message will still telegraph through as a pattern... except for maybe the scrolls. An old trick is to trace the scrolls with a magic marker before you paint the white and that will show through.
Jillbeans
Great advice, Gino.
I like the idea of cutting in.
And yup, I do have insurance.
I was thinking soap and water might be a good idea. Something like Dawn dishwashing liquid maybe?
JoySigns
Jill, you should refer to a newer sign pricing guide as well as all the other considerations...haven't your expenses gone up since 2004?
ddarlak
Go Bills!
looks more like a 10' x 24'.
screw insurance.
i'd use ronan, prep with laq. thinner.
with lift provided, i'd come in at around $3K, probably bump it up to $3.5K
