the vinyl is hexis, but if black looks good shouldn't the other colors look good?either the white is too heavy or not dry.
another issue is the fluorescent may not be printable so the ink is not absorbing/drying
noozle check is okWhat does your white nozzle check look like?
Doesn't look like the white is laying down a solid layer and the overprinted colors are reflecting that.
Black will look better because it's just darker/more opaque.
If white nozzle check is fine, try slowing head speed way down or increasing passes. We used to print white underlay with our XR-640 and had to print very slowly in order to not have overlay colors pool or look like crap.
There were times where we would even have it print white only then return to base point, then send cmyk prints down, but that's far from ideal.
you would think so but stranger things have happened.the vinyl is hexis, but if black looks good shouldn't the other colors look good?
Black is opaque and does not require a white point of any kind. You can print black on any receptive surface of any color and it will come out black. Printing any other color requires a proper white point in order to properly reproduce it.the vinyl is hexis, but if black looks good shouldn't the other colors look good?
Glad to hear you got it figured out! Thanks for coming back and letting us know. Those prints look great.Thank you all for your help I finally managed to solve the problem and everything is fine View attachment 164546 It was just setting the temperature higher Thank you all
It was an idea, but then I still had to laminate it again, it would be a lot of layers I thinkglad you found a fix! i would have suggested, as a last resort, to simply laminate the vinyl with a clear printable overlam, and let your print sink its teeth into that layer.
