Problems saving JPEG in Corel
Jessica50111
I got a new computer at work and we installed CorelDRAW 10, which I had used on my old computer with no problems. Now when I save a file as a JPEG and later view it, there is a black box that appears on the file. This happens every time I save a file as a JPEG.
We uninstalled and reinstalled Corel and it is still happening.
Any ideas out there?
Shovelhead
You..."EXPORT"...
a file as a .jpeg. You can't "SAVE AS" a .jpeg.
If youare "EXPORTING"...is "always overprint black" checked?
:Welcome: to the site.
Jessica50111
yes i meant export
Sorry - early morning. I did mean Export, not Save. I don't see where to check the Overprint Black? I don't see the option. Here is an attachment that shows what I mean. I am referring to the black rectangle at the bottom of the yellow/orange sqaure. That is not supposed to be there, and when I am exporting and looking at the preveiw, its not there.
Shovelhead
That appears only to be....
an outline around your gradient fill.
Get rid of it at the arrows.
dclet
Corel 10 may not have that, anyway... grab what you need and paste it into a new file ---- see if that works, or change the display to outlines, see if it's (the retangle) is still there. Send me "the" or "A" file I will have look. :)
Silly question, do you have something else to make a .jpg....does it happen
there too. I remember vaguely as virus that would corrupt all jpgs......
Probably not the case, but it just popped into my head :)
Did you try exporting as something else - .tif .eps etc.
Jessica50111
more discoveries
I did find out after some experimenting that if the file has an outline - the black box appears in the JPEG, on the bottom of the object. It doesn't happen unless there is an outline. Its not just one file, its every file that I try to export. In the original Corel file, the box is not there in the outlines or anything. Either I get a black box or in the middle of exporting or the Corel Recovery Manager pops up and the program shuts down. It doesn't happen on when exporting to an EPS but it does happen with TIFs.
Here is another file!
Jessica50111
and here is another case with an outline box in the middle - the black box still appears in the same spot. it's like it is haunting me :smile: it also appears if I save as a GIF. cutting and pasting doesn't work either.
dclet
hmmm, that is funky! is that a bug with version 10, x3 doesn't do that....
upgrade?
Try resetting to factory defaults press f8 at start up
Reinstall?
Use contours to get around it for the time being...
System specs?
