S
scarface
Guest
Hey everyone. Things for me have been expanding to more signs than RTA jobs like i've done before. Now for signs i usually do aluminum and coro but i got a job today doing another type which is something i haven't dealt with before and would appreciate any guidance.
Customer wants 3 signs which he will be installing himself. These will be drilled into on the corners so i'm guessing you can do this with pvc fine, again the customer is doing this also.
These are the sizes he wants them in for the areas they need to go
1 28wx15t" going on metal door
1 50wx32t" going above door onto front of garage
1 59.5wx8w" 1/2" thick for business name sign board 2 sided
Now, i was going to do a excel pvc but i can only get it in a 4x8' sheet so i would need to get for example 1 sheet 1/2" at $118 cut to the 59.5x8" size and then do just aluminum at $55 a sheet colored for the other 2 signs going on the building and metal door.
Would this be the best way to go about this? I mean i'm not 100% sure since i have never used anything outside of coro and aluminum.
The long and thin sign needs to go on this sign board i have attatched, i'll be doing only 1 which is the one circled but the others have been there for about 5 years and are made from plane jane painted wood and are flaking off.
Any guidance on a price for these off shapes as well as what to use?
Thanks!
Thanks!
