requests for quote before job specs exist
iSign
Does everyone get these bid requests?
how much is a sign?
When it is a nice restaurant in a nice building, you know they want something nice... but they have no idea what they want & seem to think they can narrow down the field to one bid-winning sign guy without having any kind of plan.
I've dealt with this too many times & usually spend too much time trying to draw out of them what they want so I can bid on it... only to never here back. I've often wondered if the other guys are keeping it quick & simple saying "Signs from $89.99"... or some other sort of vague get-your-foot-in-the-door reply.
Anyway I just typed out a reply to another similar vague quote request & I also went a little out on a limb doing a 15 minute layout hoping that will support my basic premise of suggesting they choose a company based partly on service... not just on price.
I'm posting this because I think I'd like to have a standard reply like this that could be sent out with just a few minutes of personalizing it to the specific client... & I figured it would be a familiar problem for many of you folks too, so I wondered how others handle it.
Here was my email:
Garrett,
Thank you for the opportunity to offer my company's services in regards to
Maui Brewing Company's current signage needs.
At this time it is difficult to provide a firm quote without knowing
specific materials, sizes, & the desired layout or colors. I can however
provide an estimate of some possible solutions that may meet your needs.
I usually do not spend time on design work before securing an order, but I
chose to work up a possible layout for your sign over the door. I looked at
your website & decided to see what could be done with the shape you need to
cover, & the logo & lettering you use on the site. I also felt the black &
white theme looked well established & went with that. This is just a quick
example I wanted to use to begin solving design challenges of fitting your
information & color scheme to the specific site conditions.
Here is my example as a starting place for providing an estimate & for other
design variations that could be produced.
As far as estimating costs for the sign over your door, I could give you a
fairly wide range of possibilities based on material choices & your budget.
If we use my layout for example. The cost for sign production only, assuming
an approved layout has already been designed & approved & exact dimensions
are provided, could be as low as $500 for 1/2" painted MDO plywood which is
a common substrate that has a paper coating that allows a nice glassy coat
of sign enamel to provide a background color that is free of any woodgrain
texture.
Another possible material choice is a polycarbonite sign board or PVC
material that would be durable enough for your sign & cost a little less.
Another material choice might be High Density Urethane "signfoam" (HDU)
which would only be relevant if you wanted to consider a much more dramatic
look with raised copy & graphics & a recessed background. This could be
accomplished through traditional sandblasting, or computer aided routing.
The cost for a sign of this type would depend on factors such as material
thickness, choice of background textures & various paint or epoxy finishing
of the sign. On the low end a sign out of HDU would start at $1500.
A third option is to use white plexiglass. I'm not familiar with the inside
of your restaurant, but It seems quite likely that the tile area could be
removed & the interior lighting of the restaurant could add a nice touch if
the signage over the door were translucent. The actual cost of the sign on
1/4" plex would be only slightly higher then using MDO, but the construction
work would add much more. If you were interested in that idea, I would
suggest that a building contractor replace the tile sign with a window
first. (If you outgrow that location, you could easily remove your sign &
the building does not suffer)
You asked about installation. We do offer installation & the cost for that
would be even more difficult to determine, but I would be happy to discuss
it further.
In closing I would like to add that providing competitive bids is difficult
when the specific needs of the client are not whittled down to a final spec
sheet of sizes, materials, & a completed design. I like to think that my
company consistently offers great value in all the work we do. I am not
trying to provide the lowest cost signage, but rather the highest value. I
find that some of the greatest services I can provide are problem solving &
creative brainstorming to help you with construction & design decisions
based on my knowledge of the sign industry. For clients that don't need
these services, we also pride ourselves on excellent craftsmanship using the
highest quality materials. If a client has clearly defined specifications
for all graphics & construction details, we will be happy to provide a
written quote. On jobs where some of those decisions have not yet been made
we work with the client to set a budget & provide the best solution within
that budget.
Please feel free to contact me about my desire to assist you with this
project.
Doug Allan
Island Sign
877-0688
By the way, this is their logo... my revision of the text & inclusion of the border (& spears) makes it possible to fill the space where the provious tenants sign needs to be covered.
gtjet
Unfortunately we too get a lot of "what would it cost" questions before they will give us enough info to really know the answer, they don't want to waste time, just hurry and pick the lowest priced guy. Usually these guys are just shoppers so I figure a low end sign and give them a rough ballpark number, then if they call back I start asking questions and triing to match them to a sign they need or just give them a simple low end sign if they reject the upsale.
Careful some of these guys try to get the up scale sign at the low end quote so I'm usually specific on the quick quote that it is for a low end sign. Still they will come in at say "your competition" will do it for $250 on the nicer sign but we talked to you first so if you'll match that then we will use you. Any more I say, I would lose money if I did match that price, I really want your business so I'll knock (on a $500 sign) $50 off if you prepay the sign (I have to be fair to my other customers that did not get the $50 off) and you can see the quality you will get by looking at our other signs and visiting with our customers, I hope that if fair enough, it's the best I can do.
Rick
First, with any job I ask about a budget. I don't know any businessperson who has never made one up, even if it is unrealistic-you need to get an idea on what it is.
Second, don't just offer a bid on the sign. Offer the service of designing the sign (and anything else like menus, interior decor and signs, murals and misc identity, business cards, shirts etc.) and sending it out to bid, that way you get paid for the design time and you are bidding with an exact specification. Make them come to you for everything, even if you do not make the sign, you get paid for your time and may get the misc. work that may actually pay better in the long run.
Marlene
It must be a pretty common thing as we too get people who call and ask how much a sign is without any idea of what they want. I ask them a few questions like do you want a wooden sign or lighted and sometimes they start to get a clue but for the most part, they just don't have any idea. I use the example of me calling a realtor and saying I want to buy a house, how much is one. They then, for the most part, get what I'm saying to them and start to come up with an idea of what they want. I think that they just aren't sure what they have to have in mind when they call a sign shop. The other thing I love is when they say it will have 16 words, just what is that suppose to mean? They say it like that is al we have to know to give them a price.
H
HSG
Guest
Point out that just because someone says they do signs, doesn't mean they do them well. Hiring someone to do a sign is not like hiring a plumber. I ask if someone referred me. If they say they found me in the phone book while price shopping, I give them a price range for a 4' x 8' sign, low end, mid range and high end. I also point out you get what you pay for, I'm an artist and that I've been doing this a long time and I will give you a logo and/or image to be proud of and attract the customers you want. If you already have a logo, I can expertly reproduce it for a fair price. Everyone wants something for free if they can get it. You need to convince them in as few words as possible that it will be a mistake to go elsewhere, that my company can deal with all your needs and some you might not even have thought of yet. And that will save you money. I don't usually install, I try to get them to use their own contractor, but if they don't have time or don't have one, I can provide a subcontractor to do any work they might need. I also name some of the larger local companies I work for that most people will recognize. I don't waste much time on price shoppers. I tell them to check out the work of every one they contact before making a decision. Thankyou for your call and have a nice day. Allthough I do remember one guy I actually laughed at. He claimed another sign painter would make him a 4'x8' sign with an airbrushed 2003 dodge ram truck for $400.
HSG
xtremegraphics
Doug , I think your best off not to give them any design, they will think your design time is not worth anything. Then when you try hit them with design cost they will bitch, or if they like the design in your quote they will not want to pay you for it!The letter is a good idea! I always ask what there sign budget is.
gtjet
HGS, that is exactly what we have run into and I have to admitt it is very hard not to laugh at some of these guys. Marlene, we have got the "the sign will only have so many words", how much will it cost? That is laughable too. I think I have already refined how we will visit with customers in the future, I like Ricks idea of asking for a budget, although the true price shoppers don't want to give you one as they just want to quiz 4-5 shops and narrow it down to the lower priced guys.
