Roland Camm1 PNC 1000
Store529
I bought this cutter on Facebook market place as I needed one that's is wider than my cameo pro. The problem is all my computers are windows 11 but come to find out this machine only supports XP os. Is there anyone can help me get this working on my windos 11 computers?
Smoke_Jaguar
I mean it's just glorified gcode over serial, can run it on old or new hardware as you please.
cornholio
It's definitely not plug and play. The serial parameters need to match. Tx an Rx lines need to be crossed and a form of flow control needs to be established.
Attila Nagy
What are my cable connections as I have no idea about rx and tx
Can USE USB-Parallel or USB-Serial + NULL MODEM cables.
For parallel most cables work, but not all.
For Serial need to have Cross Linked NULL MODEM cable. Baud rate and serial settings set same both cutter and software.
On the CUTTER close I/O to AUTO and COMMAND to MODE2.
Ian Stewart-Koster
Older Greyer Brushie
search PNC1000 here. I posted a heap of info 20 years ago.
BUT I could not get ours going on anything newer than win 7 on a 32 bit system.
Attila Nagy
Do not look for driver. Cutting Softwares send the commands Directly to the port. You can connect cutters to Any Windows or mac Systems. Roland Cutstudio is not a Cutting software. It is only a skin for Printer driver.
Proper cabling, and real Cutting software the key.
All 3rd party softwares support Roland commands.
Store529
I used a null modem db9 cable to a ftdi cable and a db9 to db25 adapter. It started cutting but only cut for 10-15 seconds then stop with error 15 or 16 or 3. What can I do
Attila Nagy
Check Flow control settings, some Roland cutters do not have all flow control pins connected. It can be solved in software, or with special cable. Not all softwares have full control over RS232. Set Flow Control to HardWire and COMMAND to Mode2 on the cutter.
Just a few examples:
Attila Nagy
If you do not have full control over RS232 like in EasyCut Studio, can make a special plotter cable.
