customsticker
After months and months of trying to get my contour cut to be even close to be dead on, I have comprised my experiences here. These are all experiences WITH printing, laminating and reloading with crop marks.
Some tips:
Make sure your media is reload to a similar position that it was loaded. I accomplished this by putting a peice of vinyl on the right hand side of the machine. I can ensure the feed is straight and I am reloading in the same position that it was loaded.
Turn the heat off when you cut. I haven't found this to be a huge factor, but the heat does cause the media to buckle and the blade can scrap the vinyl.
None of the user menus have any effect on the contour cuts. They are simply for the print/cut (one after another, no crop marks).
How to correct if all else fails: - In the service menu (call your tech if you don't know how to use the service menu) there are options that allow you to adjust the voltage on the crop mark detector. These volts should be at 2.3 volts, plus or minus .2. This must physically be adjusted with a screw driver within the service menu.
2nd way to correct - Much like the print/cut adjustment in the regular menus, within the service menu there is one specifically for the crop mark adjustments. These tweaks are very similar to the user menu.
It took me forever to find these adjustments, basically because I didn't think any existed. After flipping through the service manual, I found out how to pull it off.
My contour cuts are now better than ever and I no long have to send out decals that are over 1/16" off.
Hopefully this helps
Some tips:
