Need Help Roland Sp540v Servo board replace
damonCA21
Our Local Roland tech said it's the servo board, in SA there is none available, so I got one from a Sp540v same as mine that a dude was breaking up
OK it is possible he sold you a bad board then and that is why he was breaking it :(
damonCA21
To be hounest , I have a voltage meter, but not very knowledgeable on how to test voltage and stuff
Ah ok the other thing it could be is the relay has failed on the heater power board. You need to test CN101 and CN106 on it ( these are the ones that lead from the board to the fans ) . Set the meter to DC volts and put one probe on each of the pins on those connectors and see if you get a voltage reading
Ziyaad
HI Damon, I've replaced the Heater control board that i got from Roland locally. They assured me they've tested the board before giving it to me, however the issue still exist, NO FAN,
damonCA21
It needs to be connected to the heater control board, they you read the output where the fans connect to it
damonCA21
You can also then check the connections on the heater control board to see if voltage is coming from that to the heater power board. If it is but nothing is coming out to the fans then the power board is the problem
Jim Hancock
Old School Technician
Ziyaad messaged me about an old thread I posted about a fix I implemented on an SP-540 where the platen fans never turned off.
Based on a suggestion from a local tech in his area, this is a possible workaround. He has obtained a power supply for the fans themselves.
The fans can be hooked up directly to the power supply and it can be turned on and off, or it can be left on and have the output run through a toggle switch. Locate the wires that connect to the vacuum fans on the heater power board, as Damon said, it should be CN101 & CN106. Unplug these cable and cut the connector off, but leave 2 inches of wire with the connector in case you need to re-attach the connector for some reason. Take the 2 wires from each cable that go to the fans, likely a red and black wire, and either hook them to your power supply or to your toggle switch. The toggle switch needs to be a double pole switch so you can hook both sets of wires to the switch, reds together and blacks together, with 2 additional wires going from the switch to the power supply, maintaining the polarity. Just be sure the power supply is the correct voltage for the fans and you only need one power supply to run both fans.
Ziyaad
Thank you so so much Jim and Damon. I've attached pictures of the fan and also the power supply my local electronics shop gave me after showing them a picture of the fan and specs. Did they supply me with correct power supply?
AND if you go to a good HVAC industry site, you can get a fixed temperature thermister to turn the fans on& off. I will post a link, I purchased a few to keep a warehouse section warm, during thevwintr
damonCA21
Yep power supply will be fine for those. If you are going to be running the fans all day I would personally get a couple of those supplies and run one fan off each just so they aren't pushed as hard and they will last longer
Ziyaad
I want to give a huge THANK YOU to damonCA21, netsol and Jim Hancock , I have finally connected both fans as suggested by Jim, connection was from connector CN101 and CN106 on Heater power board to a 2-pole rocker switch, which then runs to the power supply as shown in my earlier post. I neatly ran the wires into a Junction box with the rocker switch on the side. After a week I am finally up and running. This forum is a god send when you in the printing industry and with people like damonCA21 , netsol and Jim Hancock always replying asap and helps you even though we not acquainted and lives miles apart. I've attached pictures of the junction box and switch.
Reactions: 1 users
damonCA21
Good stuff! Hopefully it will keep running properly now ( until the next issue comes up, which they always do at some point :D )
