Roland TRUvis VG2-540 low humidity/ static electricity issues
WEC production
Does anybody have any suggestions for low humidity. I am told it is what is causing print quality issues? banding and streaking both horizontal and vertical. All medias and all setting I can try..
Zoogee World
Have you tried increasing the humidity with a humidifier? I know this time of year where we are, it gets very dry with low humidity.
Zoogee World
Do you have a picture of how your prints are looking? Not sure if it would help, but maybe give someone here a better idea as to what the actual cause is.
WEC production
here is what I am getting... straight cmyk colors
WEC production
ok so all of a sudden I get this quality (top).. and next print looks like this (bottom) ???
Do you have something (stove, hotplate) to simply boil some water?
I don't know if a humidifier is a rental item, DEHUMIDIFIERS ARE, for flood remediation. You can go to home depot or lowes, or walmart & buy a free standing humidifier that will put 3-4 gallons of water vapor into the air. You need at least that much. As i said, i would try auction sites or facebook marketplace but if it could solve your problem in a couple hours. Has this happened other years?
WEC production
no... this is a brand new machine.. only had it about 2 months, but have had issues since day 1. I've used multiple Roland printers over the last 20 years.. and have never had issues like this.
WEC production
I'm starting to wonder if the humidity is not the issue... I talked to another guy who is at 18% humidity running TRuvis 2 inks and has never had an issue.
I suppose that series must be VERYSENSITIVE to static
Why don't you buy onevfrom amazon, you can get it tomorrow or thursday, use it for a couple days. You can always send it back, with no problem
WEC production
I've tried a humidifier... doesn't do anything to the room humididty
WEC production
whats the nozzle print look like?
nozzle print is good as far as everything is firing. I've been running test prints for weeks trying to flush the lines/ try different settings etc. Then yesterday I got 1 good print (top) and the next run was garbage again (bottom) the bottom image is what most printing looks like
bigkahuna_305
Hopefully it's humidity/static, I was having these issues and it was the profile and static that fixed my vs540 ended up printing with generic profile in my flexi and that with the static string stopped it
THEN ADD MORE!
typical for a small house, you add 10 gallons of water a day
bring a hotplate boil a large pot of water, like your wife would use if she was making lasagne
boil away 10 gallons of water
then see if it makes a difference
buy one of those anti static guns from amazon (if it doesn't work after the humidity is up, you can return the gun
REMEMBER AT LEAST 2-3 GALLONS A DAY, IF YOU WERE PRINTING WELL, MIGHT BE ENOUGH TO HOLD THE STATUS QUO
WEC production
THEN ADD MORE!
I am in the works of getting a steam humidifier installed, as well as static cord... just found another printer in town with the same machine and has never had any issues.??
