Roland Versaworks 7 sucks coconuts big time!
Adam Edge
Slow, cluncky, GUI is rubbish and most importantly ripping jobs now takes 10 times longer. Worst of all if you don't register your printer on their server within a week you can never use it again? like what the heck. My XR connected ok but the VS needs to be registered but their online registeration severs not working lol. Tried a print and Cut job on the XR, took 40min just to rip and then after laminating and changing to cut only it was ripping the file all over again and needed another 30min to an hour. I booted up version 5, it ripped the file in less than a minute and started cutting before version 7 could even get to 10%.
I have a high end PC with NVME drives, tone of DDR5 memory and latest i9.
Dont waste your time, stick to v5 and 6. Roland seriously? get your act together! Don't try to be Apple, atleast their software works!
Adam,
i assume you do not use a slow computer...
what does task manager show for resources when you are RIPing?
you must have a bottle neck in CPU, RAM or DISK USAGE.
unless they have the world's worse internal programming
perhaps you need tio add a drive for temps and working directory?
i am not going to suggest downloading a systems diagnostic program (i have that tendency to turn things into a bigger project, that can't be
helped, i guess)
post a screen shot of task manager <more details> during a rip.
for the hell of it, do a reboot afterwards, and repeat the process with the same file and do task manager again
i assume windows 11 pro?
weyandsign
let's see cpu core usage / disk usage while ripping in 7 vs 5. It says on their website, you can contact a Roland dealer to get version 7 that does not require connecting to the internet. I'm betting it's uploading every rip job to Roland. If you're using Windows, get "NetworkTrafficView" program.
Johnny Best
Is this the way you look?
Adam Edge
Adam,
helped, i guess)
if 5 and 6 are ok than no stubbynecks on my system. Installed 7 offline from files downloaded, runs offline but requireds internet connection to connect printers for the first time I believe.
Versaworks usually doesn't have much demand on CPU, i've check in the past and while ripping utilization is not even 20% on i9. But yeah ill do screen graps for both 5 and 7 and post up, lets see how they compare.
yes, Win11pro H24, 32GB DD5 dual channel 7000GB/s, 1TB 6000Gb read/write boot drive, 2TB 6500Gb read/write second file drive. All cherry picked parts from top brands. Gotta squeeze in some bragging haha
Adam Edge
thanks, ill check on that.. ;)
remember one thing,
it is a 32 bit program, and can't use any memory beyond the first 4 gigs.
that always becomes an issue
david maxwell
Mad Max Signs
I have been using Versaworks for decades and the new 7 is absolutely slower at ripping and nesting. It does seem like a step backwards, what did they improve?
T4rb6
New lol interface... need two 4k screen to have 2 work on screen lol...
but it's for everyone
they try to have the DIY market ....
Adam, I'm having the same issue after upgrading to V7. Have you figured out the issue or solution yet?? Let me know the latest.
