Roland vs 540 throwing Service Call Linear Encoder I
Zoogee World
Domed Promotional Product Supplier
SUCCESS!! I followed The guide you sent to the letter and it worked!!! :)The limit was set, I powered up the machine and printed a report that you see here. I also printed a test print after 2 moderate cleanings. As you can see I'm missing a bit of red ink there. (My machine hasn't run since the first week in October.) Do you have any suggestions to open that red line? View attachment 179684
DamenCA21 I reset the limit position and I'm up and running. A bit of a problem with that red line you see on my test print. I only have 1 head on the vs540i, Ill try to do a powerful cleaning next. Thanks for chiming in on my feed!
Axelbeta, you were correct with the limit position....I got a (Do it yourself guide) from RolandCertifiedTech and it worked~! Thanks!!!
You could try a powerful cleaning to see if that improves, another thing is to do a 48 hour head soak. My guess is that if the Magenta head was working fine before it broke down, then it's clogged nozzles.
  • Agree
Reactions: 1 user
Tigerquill
Whats the best way to soak it? Everything was working fine before I cleaned my linear scale and found that it was a mess.
