SUCCESS!!  I followed The guide you sent to the letter and it worked!!!
The limit was set, I powered up the machine and printed a report that you see here.  I also printed a test print after 2 moderate cleanings.  As you can see I'm missing a bit of red ink there. (My machine hasn't run since the first week in October.) Do you have any suggestions to open that red line?
DamenCA21 I reset the limit position and I'm up and running. A bit of a problem with that red line you see on my test print.  I only have 1 head on the vs540i, Ill try to do a powerful cleaning next.  Thanks for chiming in on my feed!
Axelbeta, you were correct with the limit position....I got a (Do it yourself guide) from RolandCertifiedTech and it worked~!  Thanks!!!
