Need Help Roland vs-640 blurr print
adrian.blasciuc
I have a problem with the print quality. It is blurred every 4-5 cm, like in pictures attached. The device is a Roland VS-640. The feed motor also has an increased speed every 5 cm, like a impulse. In my opinion I think it is from the encoder disk (have some scratches), the feed motor or the motherboard. (Also I have another problem with the printer. If I power off for several hours, it no longer turns on from the power button from the front. I have to turn it off/on from behind button, then the front button works again.).
I have error on Motor menu: G-enc. check and on Print menu: Linear check.
I also attach a print test, that looks good and some calibration test: some of them have a gap because of feed motor speed.
Jim Hancock
Old School Technician
If your encoder disk is scratched, then that is almost certainly your problem. The current part number is 1000015584, which replaced the original part number1000002162. Check Digiprint.
When your encoder reader hits a scratch, it's jumping to the next readable line, causing the feed motor to momentarily speed up until it reads that line. Keep us posted...
  • Agree
Reactions: 1 user
adrian.blasciuc
Jim Hancock, I already ordered encoder disk and linear encoder olso (to change both) from Digiprint. Next weekn I will receive it. I will keep in touch after. But what is your opinion about this: If I power off from front button for several hours, it no longer turns on from the power button from the front. I have to turn it off/on from back button, then the front button works again.
dreko
I'm having blurry prints too... What's the latest with your repair?
Encoder disk fix the issue?
adrian.blasciuc
Tomorrow i will receive both encoders (line and disk). Took one week to received it from digiprint. Then i will write here about the result. Keep in touch. I guess is the encoder the issue. Because the cut is working well. Only the print is the problem.
adrian.blasciuc
I received and installed both (the encoder disk and linear encoder). And yes, fix the issue, my print is ok now and that it is very good. Error on Motor menu: G-enc. check dissapear. But I still have the error on Service menu: Print menu: Linear check. I will replace the sensor to see if it fix it.
Now I am focuse to the second problem: If I power off from front button for several hours, it no longer turns on from the power button from the front. I have to turn it off then on from back button, then the front button works again.).
