adrian.blasciuc
I have a problem with the print quality. It is blurred every 4-5 cm, like in pictures attached. The device is a Roland VS-640. The feed motor also has an increased speed every 5 cm, like a impulse. In my opinion I think it is from the encoder disk (have some scratches), the feed motor or the motherboard. (Also I have another problem with the printer. If I power off for several hours, it no longer turns on from the power button from the front. I have to turn it off/on from behind button, then the front button works again.).
I have error on Motor menu: G-enc. check and on Print menu: Linear check.
I also attach a print test, that looks good and some calibration test: some of them have a gap because of feed motor speed.
