Need Help Roland VS540i, Brand New Printhead Zero Nozzles firing after installing
Myster Enigma
Hi Guys, So I have an issue with my VS540i. So my old printhead has been leaking whilst idle. Ink droplets would just drip from the printhead whilst nothing was happening. I've noticed this when I did a manual clean as I could see under the printhead. As well as this the printhead will often get intermittent drop outs in the nozzles, one line of black and one line of yellow will completely drop out and head cleans can fully restore them.
But eventually they dropped out again. I thought I'd change a few parts first such as the captop (No difference) and then the dampers. Initially I made a mistake and installed the dampers the wrong way round :( So when it was installed incorrectly I ran a fill ink and ink was flowing through the lines but the nozzle did not fire any ink at all. At this point I did not know the dampers were inserted incorrect. So I bought a new genuine printhead (DX7) and installed it. Again the dampers were the wrong way so nothing fired.
I took it all apart and then realised the dampers were put in wrong. So I turned all the dampers around so they are now facing the correct side. I had one spare so I actually discard one and used a new one for yellow and magenta. I primed the dampers using a syringe and pulled back in both outlet holes. I did this to all the dampers. I then installed the new printhead again, did a fill ink via the service menu. Ran a nozzle check and unfortunately still not a drop of ink from the nozzle test.
I decided to reinstall the dampers one at a time instead of pulling the printhead cover off with it. I closed the choke valve and this this. After installing there were some air in the lines so I ran fill ink (After reopening the choke valve). I could see the ink flowing back into the head. After it was done I did a nozzle check. Again absolutely nothing
I wanted to make sure that the ribbon cables haven't been affected so I installed a different printhead from my old BN20. This head had bad nozzles but it was working. I installed it and it printed a pattern (very bad but showed something) now this was the residual ink because I ran one head clean then there wasn't any pattern at all.
I tried to syringe from the captop's ink tubes but no ink is flowing and there is little resistance. My next step is to change the captop and I am awaiting this. As you can see from the photos, my old printhead was leaking. I syringe filled the captop with some eco solvent cleaner to soak it. So everytime I run a nozzle check the printhead will smear this black mark across the media.
If it's not the captop do you have any idea of what it may be? As I am now struggling with this and feel quite depressed from it
Jim Hancock
Old School Technician
Not sure what you mean by installing the dampers the wrong way. FYI, these dampers are double dampers and it doesn't matter which way they are facing as long as the up-down orientation is correct, which is impossible to mess up, as the spacing of the holes on the dampers is different on the top and bottom. If you have ink going through the head, which you will see in the cap during cleaning cycles, then your issue is electronic. To start, you need to use a multimeter to check the fuses F1 & F2 and the transistors on the main board. I've attached a pic on how to read the transistors. The pic is from a different printer, but the way to read them is the same.
Reactions: 1 users
Myster Enigma
Firstly thank you so much for the response as I wasn't sure if I would even get a reply so honestly this has made my day :) In terms of the dampers it's not that I put them upside down but I thought I had installed them facing the wrong way e.g 2 metal looking filters facing the right. I replaced these whilst looking at the service menu. I'm glad that you can orientate them both ways. I was confused because I recently bought a BN20 which had a bad head and I replaced it. In the video the person stated that the damper needs to be placed in such a way, he did not state it was a 2 way damper. Thank you for clearing that up. Yes I am seeing ink go into the waste ink tank. But as for the cap top I can't draw any ink from those tubes. I read that you should be able to draw ink from the cap station tubes whilst the printhead is parked but it seems to just be air. Does it matter which tube I syringe from as there are 2? But I will definitely buy a multimeter to check the fuses as well.
As I used a bad head to test previously and it was able to print a slight pattern due to residual ink, can the fuses still be bad?
Thank you I will buy a multimeter now
Jim Hancock
Based on your pic, I don't think it printed anything with the old head. It looks more like ink dripping getting smeared.
Multimeter -
Amazon - https://www.amazon.com/AstroAI-Digital-Multimeter-Voltage-Tester/dp/B01ISAMUA6/ref=sr_1_1_sspa?crid=1UIOZBEBY86XC&dib=eyJ2IjoiMSJ9.yVChUu6urm0P5GzWYXOJJKKjtYeRkXPCgYaxbOwUJ1HOLG2T-2yYUQbR-YlF-m4IkIsTdYNs24SvXO6tF7JhX-Nfktc7CdFO7DgRsPE2xToF5MMUCtnpZCsckWzvBSnJ2AYPRXXDtk0xEsTSdqAgUOszeSH3VXt1jg2gtClDz5HQroAotCsiFYBIxw1sL4aqpjaNC_ImBKOYASWpBZrSCb9SajLfJvbSz6H0qQ-Y13ODKI3wmCivZ6XnY1kj2k9iNaAHrp9MK5nOWor9TvM5DtYC_ceYLwGneeweA1Vli8Q.uVizhldHv9oQ1K7pn-xtA3o0It5tPHyeY_59oRf9ZHU&dib_tag=se&keywords=multimeter&qid=1755104649&sprefix=multimeter,aps,195&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
Home Depot - https://www.homedepot.com/p/Commerc...Ranging-Digital-Multimeter-DMM-8301/329388201
When trying to pull ink through the cap, always pull very gently. As this printer uses hard tubing from the cap to the pump, you can't really close off the second line, so you will need to pull from both lines at the same time. See below for the ink pulling rig I use. You are likely pulling air through the second line at the moment. For your printer, you won't use the rigid tubing in the pic. Attach the 2 flexible tubing legs to the 2 lines from the cap. Also, as this type of tubing has a tendency to permanently expand where it is attached to the bottom of the cap, I would suggest you cut off 1/8 inch of the tubing and reattach them to the cap. This will insure you don't have an air leak at the bottom of the cap.
Ink pulling rig -
https://www.signs101.com/threads/1s...deos-but-have-a-question.180737/#post-1675840
See post #12 for what you need.
Myster Enigma
Multimeter -
Ink pulling rig -
Again thank you so much for your response. I went ahead and purchased the multimeter from your Amazon link :) In the pic I shared that ink is the residue from the capping station. My previous printhead was leaking from the nozzles and I believe it had saturated the capping station when it was parked. This is the reason I replaced the printhead. I replaced the capping station first but now this new one is saturated again so all I did this time was pour around 5ml of Eco solvent cleaner into the cap station and it seems to keep smearing the printhead when I run a nozzle check. Also thanks for the detailed photos of the ink pulling rig as this helps a lot. I will do this as well and follow your instructions and report back. Again thank you so much for your detailed explanations.
Jim Hancock
You are welcome! In the meantime, keep the heads wet by doing a head soak. Power off and unplug the printer. Because of these lines being hard tubing, this is probably the easiest way to do this. Undo the wire saddles retaining the 2 cap lines. Lift them up high enough so they are above the level of the cap and tape them in place. You can now fill the cap up brimming full with cleaning solution and it shouldn't drain out. Park the head. This will protect the head from drying out.
Myster Enigma
Thank you. Yes I will do that. In terms of the new head drying out on the 2nd day of having it I did take it out of the machine and put it back in the plastic retail box. I left the old head in the printer. Today I put the new head back in the machine. Do you think it would have dried out by now? I am hoping that the new printhead won't have any issues already :(
cornholio
I little thing to add.
The orientation of the dampers should be the same. Otherwise the membranes from two adjacent dampers touch each other.
damonCA21
It sounds like you have air in the sytem and no ink is getting into the head. First thing to do is run a powerful clean. Take off the waste bottle and see if any ink is coming out into it. If it isn't then ink is not getting through the head and you need to look at the ink supply. If ink is coming through then the problem is electrical and the head is not firing.
Where did you get the replacement head? Was it a cheap 'refurbished' one?
Myster Enigma
It should be ok, especially as you are doing a head soak. Are you using Roland OEM ink?
I'm using third party ink but I have been using this for the past 6 years and it's also working fine on the new BN20 head I installed 2 weeks ago. I will change the captop first and then I will try and draw ink from the new captop in case the old captop is blocked. I will check the head fuses also. Thank you
Myster Enigma
Thank you. Yes all of the dampers are facing the same way. At first I managed the prime the inks through the dampers. I did this with the printhead cover still on (I unhooked the latches so that as I pulled the cover up, all of the dampers came off the printhead together) I primed each outlet hole. After this all of the ink lines were solid and I ran a powerful clean. Again no nozzles were firing. So next I decided to close the choke valve and take each damper off the ink line and place them into the printhead one by one just to ensure they were tightly fitted. At this point ink was flowing out of the ink lines and I placed a piece of cloth down to catch the ink. The ink lines now have air gaps in them. I connected all the ink lines again and reinstalled. Then I opened the choke valve and selected fill ink in the service menu. The ink was flowing back towards the head and I thought this would have done it. But again after a nozzle check no inks were firing. Also the ink lines have some air in them just before the head? Should there be air after running a fill ink?
Myster Enigma
Thank you for your response. Yes this is a genuine head and the same thing has happened to 3 different heads that I tried. I ran a powerful clean and a little bit of ink is going into the waste ink tank. After running fill ink more ink is going in so it seems like ink is going into the waste bottle. I did ask chatgpt (Probably very inaccurate advice) but it suggested that even though ink is going into the waste bottle it doesn't necessarily mean the ink is going through the head to the bottle? Is this possible as I thought that the only way ink get in the bottle is through the head.
Myster Enigma
I'm waiting for the new captop and multimeter to arrive but in the meantime I've attached a photo of what the nozzle check looked like before I started replacing anything. The photo is edited as I threw the original nozzle check away but it looked similar to that. Keep in mind the printhead was also leaking. So at first I only changed the dampers as I thought they were the problems causing the leak. I ran one nozzle check and the pattern was exactly the same as the photo. So I thought okay that worked but I need to run a clean. I ran one medium clean and then the head went completely blank. Then I took out the printhead and replaced it with my old BN20 printhead (Bad nozzles) I ran a nozzle check and it did show a pattern. It was a bad pattern but clearly it fired something. I ran a clean and again it was blank. My assumption is that the heads are firing residual ink left inside the printhead. Is this correct? Also would a bad head fuse still enable a printhead to fire any pattern at all?
Jim Hancock
If there is ink coming through the head, then again this is an electronic issue. I would wait until you can check the fuses before doing anything more.
cornholio
If you see drops of ink on the nozzle plate during a normal cleaning, before it gets wiped clean, you should at least see some nozzles firing in a nozzle test.
Otherwise it's electrical for sure.
damonCA21
Chat GPT is wrong ( as it often is ). The only way ink can get into the bottle is through the head. If the ink supply is good then you should be getting quite a lot of ink coming through on a powerful clean like big spurts each time the motor turns. If you arent getting this then something is wrong with the ink supply to the heads but as the others say if you are getting some ink into the head then you should have some output on the test prints so check the mainboard fuses as well
Myster Enigma
Hi guys, thank you for all of your responses. So the capping station and multimeter arrived today. I changed the captop and ran one normal and one powerful clean. From the normal clean there was no ink at all on the captop but from the powerful clean you can see from the 2nd image ink has been drawn. However after the powerful clean the ink from the ink line (Yellow) hadn't budged at all. I'm not sure what to make of this.
So with the multimeter do I have it on the correct setting as shown in the photo? I've never used one before, I went onto YouTube but still don't understand how to use it. with the F1 & F2 and the transistors is that on the main board? How do I check the F1 and f2 fuses. Do I put one pin on each side? Also do I have to press any buttons on the multimeter. Sorry for the questions.
damonCA21
Yes hold one probe to each end of the fuse and it should beep if the fuse is ok ( if you hold the two probes together on the setting you have in the photo it will beep ). No beep and the fuse has blown. For no ink output at all it would need all multiple shorted transistors which is very unlikely., I do repairs on Roland boards and have never seen it happen.
Your yellow definitely still has air in the line so there is a problem there as a couple of powerful cleans should clear that.
To explain a bit more. When the printer does a clean it doesn't fire the heads at all, it just uses the pressure from the pump to draw ink manually through the heads.
Looking at your captop after the clean there is definitely a problem with the ink supply as you should see a rainbow of ink colours all across the captop .
To be honest at this point I would get a tech in as you are quite likely to cause more damage and end up needing another head. Sometimes it is false economy to try and change it yourself if you don't know what you are doing, and the DX7 heads are awkward to work on
Myster Enigma
Thank you for your response. I have left the office now but will give the board a test on Monday. But from what you're saying, it doesn't sound like the fuses as it's unlikely for no ink output at all unless they are all blown. Of course I will test this as the next step.
Ah okay so the heads don't fire from head cleaning, I always thought it had to. I just have a feeling that when I test the fuses on Monday that they will be fine. I really didn't want to get a tech in because they charge a ridiculous amount and a reputable one from where I live in the UK will want to replace everything else including the print head as they have suggested in the past that all parts must be from them. The only reason why I decided to have a go myself is because me and my partner recently bought a used BN20 with a bad printhead. I went online and watched a video on how to change the head and done it myself successfully. I thought being as they both used DX7 heads it will be very similar. The difference is that I didn't have to go into the service menu for the BN20.
At this point I'm willing to try another week and if the print head gets damaged I'll just have to deal with it :( If it isn't the fuses could it be the pump at all being weak or old as it hasn't been replaced since 2019. I have also attached a photo of the ribbon cables going back into the head. I believe this is correct. Also is there something in the service menu I can run a check on or maybe something that I can change. I definitely opened the choke valves again and did a choke clean.
I really don't want to trade this in or get rid of the machine as it had been great up until this point
Thank you
