Setting Registry Marks?
anozira02
Member
I have a Roland Fj-52 and can't seems to find where to go and set the registration marks for my cutter. I am using Flexi 7.6 and looked there as well... can anyone give me a hint?
CropMarks
Member
I was going bananas trying to figure out what cutter to go with and how to come up with a print and cut workflow that would work with my SJ540. I finally went with the graphtec because it had the super easy to use plug-in for illustrator.
Someone also pointed me to some web videos that signwarehouse had dealing with contour cutting with a prismjet extra....
http://www.signwarehouse.com/tv/?p=19
you have to scroll down to see the contour cut section... it might help... or it might not.
sfr table hockey
Very Active Member
Go into production manager and either add a file to print and double click on it or go into set default properties. Go into the 5th tab over (lables and marks) and look about 2/3 down the page for "print marks".
If you set up a SC 500 as a printer you could still print on the FJ with that setup and then there will be a crop mark area in printer options.
This is from a newer version of flexi but you should find similar in 7.6.
