Side mount hardware for an aluminum sign
nolanola
https://manhattansignshop.nyc/
Hello.
Is there a pre manufactured hardware to attach a sign to a wall from a side?
attachment.php
But for large signs?
It will be a double sided aluminum sign 48″ x 24″.
Thank you.
nolanola
I think there should be a frame and the aluminum panels should be bent on the edges, so the fasteners go from the sides.
Is it the right way of doing it?
Thank you.
attachment.php
to make it look like this, only with no illumination
attachment.php
Starter
2 pieces of 1x1 aluminum angle "sandwiching" the sign is an option. You can shine/clean the angle with a scotchbrite pad.
Billct2
For a little interior sign sure, for anything large outside, no.
One way, have a frame with the fastening plates welded as one unit.
Attached to wall and then skin it
