Source for these style of exit signs?
sinclairgraphics1
Sinclair Graphics & Installations
Good morning, trying to find a supplier for these style of signs. I found a company that supposedly makes them but they haven't returned my messages. If anyone has a source for these or can produce them please let me know.
Notarealsignguy
Arial - it's almost helvetica
Those are explosion proof fixtures. The sign would likely need to be UL listed even if it is not self lit. You can buy explosion proof exit signs, they are $$$
rjssigns
Could be from here...
sinclairgraphics1
Yeah, they are pricey, not even worth me ordering and marking it up for my customer. I'll just send them straight to the source.
Johnny Best
You could make those thin plastic covers that say Exit really easily, and charge accordingly. Why would you pass on something so easy to do and make some money?
sinclairgraphics1
Sure, but it needs to be blast proof. Is this something you can make easily? I pass on stuff not worth my time. If you can make them, I'll certainly purchase them from you.
Geneva Olson
Expert Storyteller
I'm curious about the terms, "blast proof" and "fire retardant". I'm also confused about the regulations on these things. Like, what exactly about that sign contributes to a blast if there is a fire? Like how much of a blast is it going to create?
Notarealsignguy
Explosion proof. It's a lighting fixture in a class 1 division 1 area. Everything has to be explosion proof meaning, the conduit and boxes can contain an explosion inside of the bodies without igniting the potentially explosive atmosphere that it is in. The conduits have seal offs to prevent the internal explosions from migrating through the whole electrical system and each box is machine fit which allows the gasses to escape from an internal explosion without igniting and/or blowing the stuff apart. It's all threaded rigid pipe.
The concern would be the material used for the sign melting or burning because it is right on the light fixture. Every electrical component is UL and would assume that the sign would also need a UL approval for that use.
Here's one exploding a few counties over. Seems someone had a burrito for supper, went back to work and f@rted. They were using Johnny's version. Lit up the whole night sky.
