Spot color not printing spot color
Jharris81
So I want to print a sticker with just black, so I made sure that the graphic in illustrator was BK21A which is 100% K. Even shows up that way in Versaworks as the spot color but under magnification I can sure see magenta around the edges. I haven't worked to much with spot colors because I haven't really had to but is there something I need to change to make this happen. It's a very small graphic so I just wanted to do 100% K so I didn't have to worry about the head lining up just perfect. I am printing with max density profile.
damonCA21
it is probably down to your profile settings in versaworks. You can change this to density control only and it will print just using the black head without applying a profile to it
Jharris81
I know you can do this with density control but I figured if I used “black” BK21A it would but down just black in. Thought that was the whole point of spot colors.
