You're saying order directly from Glass Apeel? I just ordered a sample roll also. $454 for 54"x100' on Fellers. I'm not sure I would sell enough of it to buy a roll, might be something I would just order from others.I just looked this up on Grimco and it's a lot more expensive than the price list I was given from them.
Try Spot On Clear....a drunk monkey can put it up without bubbles or wrinkles and it will remove cleanly after a few months. We sell this product to national retailers like cell phone companies, Tim Horton's, McDonalds etc.So I've started getting other jobs to quote and have a job of 3000 - 6" x 6" window clings signs for banks to put up for some temporary signage. (Think it's for a holiday)
I've never printed on static cling and just did my first job with clear and white on my UCJV330 which worked fine. No issues with that.
I'm assuming these may stay up for about 1-2 months approx. Will be placed on the inside of window or door glass so they will be reverse printed with white. I need to print 270 each of 11 versions. (total 2790 window clings)
Just wondering if a static cling or a removable low-tac clear made for windows would be best?
Any kind of troubles I should be weary of when printing to static cling on a UV printer?
Stacy - Next time you need some, try Spot ON. Much less expensive. I'm on vacation but it is well under $400/roll for a 54"x164'. You'll put a ton of money back in your pocket.You're saying order directly from Glass Apeel? I just ordered a sample roll also. $454 for 54"x100' on Fellers. I'm not sure I would sell enough of it to buy a roll, might be something I would just order from others.
Which side of the cling film is being inked? For best adhesion to glass and non-ferrous metals, ink should be printed on the opposite side of contact to the substrate.One thing to be aware of with static cling is that you should leave some unprinted white space around the edge of the decal as ink significantly reduces how well the cling adheres to glass etc.
These are going to be reverse printed for placing on the inside of a window to face outside.Which side of the cling film is being inked? For best adhesion to glass and non-ferrous metals, ink should be printed on the opposite side of contact to the substrate.
see post 26...Who prints on the clingy side that adheres to the glass? Does it really need to be said NOT to? The first clue is the liner that should remain on the static cling material until you install it.
I didn't take that to mean MrDave is printing on the clingy side, I thought he meant to leave a border around the artwork on the printable side. .....which I don't do, I've never noticed that it made any difference.see post 26...
That is because it doesn't make any difference...unless the user buys white cling, prints in reverse, and attempts to mount the media to the second surface with the ink side adhering to the glass.I didn't take that to mean MrDave is printing on the clingy side, I thought he meant to leave a border around the artwork on the printable side. .....which I don't do, I've never noticed that it made any difference.
Well, thanks for the PSA for those who try to print on the clingy side![]()
Yes, I do have white. Only reason I had quoted that job for them so I can put some use to my UCJV330.If you have white ink capabilities you should go that route. Just guessing... Whoever produced their sample probably didn't have that capability, so they had to use more material to back it.
I did the same thing with GSG and Fellers.I AM TOLD, when grimco is higher, you can call, have a salesman appointed to your account
then you can have a call with him and have the price adjusted
whn i spoke to grimco, i asked, "is the pricing set, then, going forward?"
the answer is no, you have to do it every time
i have not ordered from grimco since then, but, for a specialty material, that truly is better, you would probably be well advised to go through the process
do your homework & be prepared to tell them who offers a lower price, AND WHAT IT IS
