straighten this out
pablo11059
hi all
i was wondering if you all could point me in the right direction.
in the attached artwork, i scanned this graphic and as you can see the lines are not at all correct. normally i would just play with nodes for hours to get what i need. was wondering if there are any other short cuts you guys might be able to point out. i have obviously removed nodes and the such. just wondering if there is another aproach im missing. ie... is there a way to constrain a part of a curve and make the rest follow ? or.... there has to be another way.
thanks in advance
animenick65
Is that what it looks like scanned, or vector art you derived from the scanned artwork? I personally would just produce it with the pen tool and get it the way I want/need. Are you using curves with your nodes and not just straight lines?
The Vector Doctor
Chief Bezier Manipulator
You will waste too much time fixing nodes. The curves can be drawn with ovals. Overlap them to match and use the knockout tool to remove the unwanted parts
I often get autotraced logos to fix and it is far easier to start from scratch.
pablo11059
thanks for reply
well first off im new not to computers but to vector art.
to first post i agree im not sure i have the ability to recreate this, i know its simple but not to sure how to even start.
( i have read a few books and lidya training but curves are hard for me to make for some reason) if i try to do by hand it comes out with the same or worse results
to second post yes i scanned and then vectorised it by way of adobe streamline, nodes are curves. the font would be removed and i would just replace that. but to clean up this mess ????????
J Hill Designs
draw three ovals and use the middle one to cut out the other two...2 minutes
ok the instructions weren't quite right, but the timing was fairly close...
pablo11059
j hill
not 2 min for me. lol im working on it.
i see making it new is much easier than spending wasted hours on nodes.
thanks 4 info all
cptcorn
adad
2 minutes. It's not exact... but its close.. and you could make it exact if you had 4 minutes. Should give you a good idea of what people are saying.
The text itself is just Times, and as you get more familiar, you'll pick that up... Or a few members on here will school you with their knowledge of typography.
