CraftixDesign
Hello together,
I'm new here and happy to have found this forum.
I got a summa t1400 pro with opus sensor and the plotter is running via LPT cable for now. Im trying to get it run via serial to usb, so i can use it with my notebook with windows 11.
What i found out, i need a serial cable with the following connections:
FTDI Cable (PC Side) -> Cutter / Plotter Side
Pin 2 (RxD) -> Pin 3 (TxD)
Pin 3 (TxD) -> Pin 2 (RxD)
Pin 5 (GND) -> Pin 5 (GND)
Pin 7 (RTS) -> Pin 8 (CTS)
Pin 8 (CTS) -> Pin 4 (DTR) or Pin 7 (RTS)
I have to use the following com port configuration:
The default settings of the cutter are as follows:
Baud Rate : 9600
Data Bits : 8
Parity : None
Stop Bits : 2
Flow Control : Hardware or XON/XOFF
I configures this for the com port (windows hardware configuration) and in the configuration for the plotter in winplot.
First i bought a cheap FTDI adapter from amazon, but i got only data errors at the plotter. Now i ordered the summa recommended UC232R “ChiPi” Minimum Component FT232RL USB to RS232 Converter Cable.
https://www.antratek.be/uc232r-10
Have someone get this running (serial to USB connection)?
Any help would be greatly appreciated.
THX & BR,
Sascha
Baud Rate : 9600
Data Bits : 8
Parity : None
Stop Bits : 2
THX & BR,
Sascha
