Need Help Trimming Margins while printing on eco-solvent printer
Luccha
I am currently using wit-color eco-solvent printer. In most of the prints there is an equal white margins left on both the side. Is there any attachment or custom solution that can trim the white portion while printing. My printer is not print and cut. Please help
hybriddesign
owner Hybrid Design
we used to attach razor knifes to the printer to trim as we printed. This doesn’t always work well though as the media may curl. Most people trying to do this do it on a laminator after the media has out gassed / dried for a while.
  • Agree
Reactions: 1 user
MikePro
pushing media through a blade just sounds like a recipe for buckling.
sounds like a job for a blade-collar on the takeup core? like a circularsaw-style collar full of Xacto blades that cuts as it winds?
  • Agree
Reactions: 1 user
balstestrat
Problem Solver
Many printers have slitters. You can 3D print a holder for a blade and attach it as you wish. But you must collect it on the take-up otherwise it's not going to work.
  • Agree
Reactions: 1 user
Luccha
I guess, we have to attach a circular blade on the take-up pro system. But I am not sure how that will work as both the trimmed media and the printed media has to be rolled up so that it does not loose strength needed for the blade to work.
Luccha
Any pointers for the slitting system. I searched on web but they are a separate system like xy cutters
balstestrat
Problem Solver
images
greysquirrel
there is no inline slitters for any printer that I am aware of. Fotobo has an xy cutter but if you do anything rigid or plan on cutting anything rigid you should just get a router that is belt driven.
Johnny Best
We hang two light employees with cacti knives and they cut material as it feeds. They are only good for an hour because the blood rushes to their heads.
  • Hilarious!
  • Agree
Reactions: 3 users
Luccha
Can you suggest me any automated system that can hang employees every day and unhang them when the work is done.
balstestrat
Problem Solver
Just above you I show two different systems :help
One Mimaki, one HP.
Also some laminator manufacturers make very simple systems. Just extruded aluminium, blade holder with blades pushing down. Channel under the material so blade will push through.
  • Agree
Reactions: 1 user
Luccha
One Mimaki, one HP.
Thanks for the image and video. I finally get an idea on how to mount it. I now need blade holder and mounting system. HP latex in-line slitter is a costly affair, I am hopeful some customizable solution may achieve this with low cost.
balstestrat
Problem Solver
Yeah but that's very over engineered. Like I said you can do the same with a rail or two, 3d printer and blades.
