Update on power supply
binki
I was able to get someone from Roland to actually respond to me even though they don't support this printer any more. Here is what I need.
I need recommendations on where I can purchase one. I saw one at Digiprint but I have not heard good things about them. My local authorized dealer is really dragging their feet in getting back to me.
the part number for the VS-300 power supply
1000006130
Power Unit, LEB150F-0536-XRLD A
damonCA21
Hi, I have them in stock. They are used and tested fully working original ones. If you want to message me on here I can give you the details. I am in the UK but send parts worldwide all the time
JSIGN
There is also a supplier called Radwell that has many such parts from many disciplines - if they don't have any used parts in stock they can repair for you.
Smoke_Jaguar
With the availability of techs in most areas, it's good to learn both. Otherwise, you get stuck paying idiots like me the big bucks to plug a cable back in.
  • Hilarious!
Reactions: 1 users
Wbgofd
It would have been very easy to test the PSU first...
How do you test the Power Supply Unit and is there a way to test the Main Board on a Vercacamm 540 VPI? I am having the same trouble, the machine will not start up, no display, no beep, pump clicking. There is 1 green LED light that comes on the carriage board. Any help or suggestions would be greatly appreciated.
Thank You,
Larry
damonCA21
If you have a green light on the carriage board then the power supply is ok This shows the printer is getting the 5V supply it needs to power the boards. There isn't a simple way to just test a mainboard sadly. It could be the main panel, panel cable, mainboard etc.. and you need to know how to trace voltages and diagnose faults
we USED TO REPAIR that type of power supply.
FOR OTHER INDUSTRIES we had a company that sold you a KIT with all the renewable parts. (change everything in the kit & 95% of the time it works)
those things really need to be tested UNDER LOAD with temperature monitored
the only way to troubleshoot to component level is with a HUNTRON TRACKER 2000 or whatever is the newest equipment that uses that technology
the big limitation is ROLAND intends to supply complete circuit boards, so there is no reason to provide information to support you troubleshooting to component level
Reactions: 1 users
damonCA21
I agree partly. You can test at component level with multimeters and capacitance meters and a scope, but only if you know the power supply well and what it should be reading, and often only if a component is obviously faulty. As you say though Roland have never released this information, so it is only from experience
damonCA21
Plug it to a wall and check the output. Don't get shocked...
TBH if someone needs to ask how to test a power supply, they probably shouldn't be messing with mains electricity and should get some qualified to do it for them. Not knowing where to touch or put your probes can be fatal
in a perfect world, with a working one, next to the bad one, you can possibly get through it.
but anyone who doesn't know the difference between a zener diode, a mosfet &an opto isolator is bound to be disappointed
if you expect to fix these things quickly enough to be sucessful, AND BE ABLE TO GUARANTEE IT the huntron and a stack of service manuals WITH COMPONENT LEVEL INFO will
be a big help
binki
The current diagnosis is the power switch that turns the machine on and off. Having one shipped out.
