US map with separate states for cut vinyl?
MindsEyeOpen
I am working on a US map for a customer that is going to be applied to a glass wall. We are cutting it out of etched glass style vinyl. The issue I am running into is finding a vector map that has a big enough gap between the states to show a good separation. This map is going to be like 5ft wide. Anyone come across anything that would work for this?
I've downloaded at least 20 or 30 vector maps but none really give me enough room between the states. I suppose my last resort is manually moving each state and setting it up myself, but that would really be a pain.
The Vector Doctor
Chief Bezier Manipulator
do a negative outline (inline) of each state. They will be distorted (lose some detail) but it will work. Just don't pick too much of an inline. Then delete the original outline shapes
HulkSmash
You're not going to find it pre separated.. just do it yourself. the 2-3 hrs you spend looking for it, you coulda had it done a few times. :thumb:
MindsEyeOpen
:doh:
I feel like an idiot for not thinking of that myself. Forest for the trees type thing I suppose.
Billct2
If you have a good vector file you could do an inline/outline and delete the original about 5 minutes.
MindsEyeOpen
It isn't so much the time that it would take, really. I have started to do it myself several times but the results just don't look that great.
Pat Whatley
Don't know if it's clean enough for what you're doing but here's one I did a couple of years ago. We screen printed them on poster board so third graders could color in the states as they learned about them. The map in the pdf is in vector format. If you can't extract it shoot me an email and I'll send you the eps. It doesn't have Alaska and Hawaii, I can't remember why.
signsinseconds@gmail.com
  • map.pdf
MindsEyeOpen
Actually, that is absolutely perfect! Thanks!
HulkSmash
i just took pats vector, deleted the background, offset the path by like -.02, cut and pasted it in a new document. Worked pretty well.. good luck
Pat Whatley
Leave my artwork alone. You want to mess with some artwork you go autotrace your own map. I spent countless minutes on that...it was not meant to be toyed with. I think the lack of oxygen in the air up in Denver is messing with your judgement. :noway:
MindsEyeOpen
LOL!
Luckily for me, I didn't have to change a thing. It worked great. I'll post pics of the sample I'm working on as soon as it is done.
jayhawksigns
Did something similar last year, 14' routered pvc, getting a map to work took a bit but I am happy with the final outcome. Let me know if you need another option to work from.
MindsEyeOpen
That is very similar in concept to what I am working on. It is for the lobby of a companies main office. I'm reversing the map and applying it to the back of the glass wall and then putting location markers on the front side of the wall to show their various locations and give it some depth.
I hope it comes out as cool in the end as it looks in my mind right now. :Big Laugh
HulkSmash
oh pat,
How could i ever make it up to you? Oh, i know.
I present to you the tie dye unicorn vector.
thank me later :smile:
  • Pro_unicorn.pdf
JR's
Colorado, I hope you dont get up set but I needed a Tie Dye horse. so I messed with your unicorn a little. ;-} snip snip.
JR lol
Pat Whatley
Sweet! I can sell the heck out of some rainbow unicorn window stickers, especially if I make him look like he's peeing on something!
Ha Ha Sucker....I'm gonna be rich!
