USB connection cable ?
brainnew
My Net tool IP is down some time. It's take time to set up the renew IP.
I wonder I should temporary use USB to connect direct to my SP 540V.
But the plug in on printer (the one next to ethernet blinking green light)is look a like PS/2 (mouse or keyboard) plug.
Could I use the adaptor to convert one end of USB cable to connect to printer?
Or which way to connect USB cable to printer.
Thanks for your recommend.:help:
Brainnew
chopper
I think those are Ethernet only connections I think those other plugs are for programing at the factory, //chopper
Techman
you should have a converter tail their,, i have one for my encad. One end goes into that round socket the other has the input plug..
brainnew
Thanks for your suggesting.
I have one round of Encad, but I think it's for Mac connector.
Keep thinking for learning.
Thanks again
Brainnew
jester2kx
I would try and figure out why your IP gets goofed up. Could it be that your computer (not the printer) is losing its IP address? You may want to try and staticly assign it, so it doesnt need to DHCP if it is losing it.
