Using Pvc for hanging sign
David Wright
I have four signs I will be making to hang from a scroll bracket outside.
General sizes will be 28" wide by 36" tall, double sided.
Can I use 12mm (1/2") pvc/sintra for this and expect no warping or other issues?
Billct2
I like the idea of 1", both for rigidity & weight.
I have bonded two pieces of 1/2" together to make a 1" thick panel
ChaseO
If using 1 inch, make sure you have the bracket anchored well, and if on a pole, make sure it's in the ground really well. That's a lot of weight over time and we have all seen our fair share of drooping, hanging signs over the years. If I were going to make a sign like that, I would fab up the hangers that would clamp the panel on both sides too so it didn't rip out the holes the first storm that came along.
I make all of my hanging sign out of two pieces. I cut a 5/16 grove in the back of the signs and embed 1/4 steel rod bent to a shape of horseshoe with ends bend to eyelet . I use pins and epoxy to join two panel together.
Zac
Project Manager
I've done something similar. In my case it was 1/2" PVC and routed a groove in the back of only 1 sign and hung it using aircraft wire through the groove and then just joined the panels back to back. It worked great and was self leveling. then we just slid PVC pipe painted silver over the aircraft wire and mounted using ceiling tile clips. Looks great after 2 years still.
