UV Printing on Mirror Tint
kalvix
Ok, we have a retail client who is looking for a one way window film and doesn't like Perf. so i was wondering about using a mirror tint and UV printing on it for the graphics? We have white ink on a UV Printer so does anyone have experience on printing on tint?
Kalvix
MikePro
agreed, try it. only issue I could see happening is the reflection curing/gumming-up ink onto your printheads
(I don't have a UV printer, but always heard that was an issue with reflective materials)
worst-case, switch to printing on clear vinyl and laminating onto to the one-way film, or simply apply to window separately
Modern Ink Signs
Ooooooooo!
Reflection from mirrored vinyl is asking for trouble!
I would not print that on my printer! Not to mention UV inks are more "brittle" / hard when they are cured.
I say just because you CAN does not mean you SHOULD.
SignMeUpGraphics
Super Active Member
Ooooooooo!
Eh, I think this is very dependent on the printer (particular lamp placement).
We've got an Arizona and print white onto mirrors several times a week for the last 3 years.
Never had ink cure to a head in all that time.
TSC1985
Reverse print to clear and apply that on window first then apply mirrored film over that? More steps/cost but seems like it would do the trick.
Pauly
Printrade.com.au
You can only try. The uv light should not reflect onto the print heads unless your heights are wrong. I'd be using low lamp heat/intensity also.
UV flatbed? or roll? it does help knowing what printer you're using.
burgmurk
this is the only way i can see this working. spring for the optically clear stuff too.
