wall graphic
WOODBS
i am putting a wall graphic up at a car dealership using 3551 w/215. it is going on a section 10-12 feet from the ground and will be a total of 52"x20'. not sure if we will use scaffold or mobile cherry picker, but what would you charge for the job, either way? thanks
Typestries
have you tested the 3551 on the wall yet? Air release films are NOT designed to adhere to latex painted walls. we have always used 3651 on walls with great success and it goes down well, never a failure. Also what's the floor? be careful putting a 1k lb scissor lift on thier floor you dont want to fix their cracked tiles.
around $1100 plus design (varies) plus scaffold rental (maybe $150?) plus $600 or so on the install to cover prep, picking up the scaffold, set up, install, breakdown, scaffold return, etc.
cdiesel
That's funny!
No need for a scissor, tho.. as long as you can get a hand on the install. We'd just use two guys on ladders for this one. The install would take a little longer, but it'd still be faster than setting up/taking down scaffold, and cheaper than using a scissor, which probably wouldn't buy you much time anyways.
I'd charge in the $1200-$1400 range, plus design, installed within range of our shop.
WOODBS
cool, that's about where i am $$ wise, as far as 3651 , i have had some curling with it, ?? i don't have time to order anything else.. i have plenty of 3551..as they want it tuesday...nice notice huh?
