Welding text and a object
josh29j
I have VE LXi Master and i am trying to weld text and a flame object together. I did it once and now it is not working Plz help
josh
CenturySigns
Custom Sign Shop Designer
Hey Josh
I don't really know what VE LXi is but most vector based programs have to have their text converted to outline form, vector, or curves. If the flames are a bitmap they will have to be traced into a curve or outline as well before they can be welded together with the text.
josh29j
ok
MobileImpact
extend the bottom of the Y so it is touching the flames, then select both items and go to effects-combine-weld.
Kevin
SAS
I use flexi but you can try Effects / Combine / then Weld
Well Kevin beat me to it.
Fred Weiss
Check to see that they have exactly the same fill and stroke (if any) settings. You can only weld objects with identical fills.
MobileImpact
not sure about your software, but i know it's a stripped down version of flexi. Do you have a box opened up called design central or fill stroke editor? if so thats how you check to see if they are the same. Also if you select an item and look in the lower right hand corner of your monitor, it will show you a couple boxes that show the attributes of the fill and stroke.
Hope this helps,
Kevin
Replicator
Highlight the objects you want welded and then click effects, combine, weld !
Sites&Signs
I know this doesn't make much sense but try changing the colors of both the Y & flame to say black (or any color, just make the change to both in same color). This happens to me sometimes... and changing the color works. Don't know why.. but it does...
In Flexi (and it's OEM versions) there is a parameter in the Preferences dialog box called Weld based on Color. If it's checked, only objects with the same fill color will weld. If it's unchecked, any color will weld.
bob
Only if you have specified 'Weld Based on Color'.
If not, you can weld any object to any other object. The resultant composite will take on the fill and stroke of the topmost object. If that object is sporting an outline, not a stroke, then the resultant composite will take on the color and characteristics of the outline. In this case Flexi treats the outline as the topmost object.
