Where would you be with this?
Sign_Boy
Hey all,
I was wondering where would you be at with this one?
Qty: 21
Material: .040 Aluminum
Size: 72" Wide x 10" Tall
One Sided One Color Vinyl
Simple Text
Thanks in advance
njsigns
I just ran it through Estimate and I'd be in the neighborhood of about $75 each if they are all the same, and about $95 each if they were all different - using cast vinyl. It seems a little low to me, but that's what I came up with based on the info provided.
Gene
Sign_Boy
Thanks Gene -
I came up with $105 ea but wasn't sure if I was way off.
Here's the other thing....
I may end up re-lettering the existing panels that are there so I was thinking if I was low on the new faces I would probably be real low on the re-letter. Don't want that to happen:banghead:
Fred Weiss
I figured it at $16 each in materials using cast vinyl and half an hour each in time. I typically double materials and have a $75 an hour shop rate.
$16 x 2 = $32.00
$75 x .5 = $37.50
Price each = $69.50
njsigns
If there was any chance I might have to reface existing panels I'd certainly pad it a little...
Gene
Sign_Boy
Thank you Fred & Jill
Gene, You're right. It's one of those strange situations.
The new panels wouldn't take that long to letter.
The customer said he would do the install - easy enough.
Now re-lettering the existing faces, that's a different story.
The signs are spread throughout a parking lot, I would need a ladder and who knows what the face is like.
They want me to price it both ways - The more I think about it I'm beginning to think the new .040 would cost less than a re-letter:banghead:
Jillbeans
When I did this type of job (subcontracting for my brother's company)
I charged an hourly rate to un-letter the existing signs
(on a ladder, in the cold)
then a price per sign charge to apply new decals.
My stuff was a lot smaller though.
(18"x24")
And even tho I sent a proposal with the changes in writing, there was a spelling error in a name so I had to go back again
(on a ladder, in the cold and rain)
So be sure you CYA on this one.
Sign_Boy
Jill - they are going to remove the existing lettering. (That's what I was told) As for the spelling on this job, it's a simple one (even for me):ROFLMAO:
I'll be sure to CMA... :thumb:
GB2
Old Member
Okay, now this is a little interesting, I just ran your project in my Estimate 2.0 like Gene, but I came up with $43.24 each using White .040" aluminum and a standard one color cast vinyl. I'd sure like to sit down with you Gene and compare our Estimate set up to find out why there is such a great discrepancy.
I also did a job last week just like this one, except I was using blue aluminum and reflective vinyl, and I actually charged $61 for the 72" x 10" panels only and an hourly rate for the installation. I'm sure that it would cost more to re-letter the existing panels than to replace them if you figure your time properly.
Sign_Boy
Thank you Gary.
I've been thinking about this for a while now.
I have 3 different price guides 4 if you include my copy of the 2006 mini sign contractors guide. They all have different prices. I understand pricing depends on overhead - hourly rate - and so on but in the end one might think the prices would be close. We all pay about the same price for the materials...
Here's what we have so far.
$75.00
$69.50
$90.00
$105.00
$43.24
I just don't get it:banghead:
OK I'm probably high on this I should be closer to Jill
Steve G.
For that quantity I'd be at 63.50 each using GraphixCalc Pro.
I double checked the numbers and they're good for me at $60/hr shop rate.
GB2
Old Member
Well, if you have any doubts...follow Fred's advice, he's the only one who actually used an intelligent method to reply to your question while the rest of us are bumbling around with faulty software and guesses!
Just to elaborate on the job that I completed last week, I charged $12 per square foot for the lettered aluminum panels, of which there were 15 in total of varied sizes and $480 for the installation. Using that formula, your job would be 21 x $60 = $1260 + $480 = $1740, providing for an 8 hour @ $60 installation rate.
njsigns
I think it really comes down to shop rate and how much you mark up your products - I've checked my Estimate (v1.991) against the Sign Craft Pricing Guide on many occassions and it always comes real close.
The 2010 Sign Craft Pricing Guide says (for my shop rate - which I actually calculated several years ago) that a 3 sq foot sign should be $76 and a 6 sq foot sign should be $140.
The signs he is talking about comes to 5 sq feet total - so if this were my job I'd spend a little time calculating...
$140-$76= $64 (the difference between Sign Craft's 6 sq ft sign and 3 sq ft sign)
$64/3 sq ft = $21.33 (each additional sq ft cost)
21.33 x 2 = 42.66 (you need 2 more sq ft to make it 5 sq ft)
$76 + $42.66 = $118.66 - is close to where I'm guessing Sign Craft would price this sign.
I just recalculated this in Estimate for one sign, using 24"x10 yard roll of vinyl (cast) and 16 minutes of design time (which is something I didn't include earlier) - this time I came up with $110.00 - if using a 24"x50 yard roll and came up with $103.25 - so I'm in the ball park with Sign Craft on one sign - close enough for me.
Now here is where I think you'll get many discrepancies - I am using 16 minutes of design time for 1 sign, now if each of these signs is the same that is fine - I just type 21 in the quantity - and get $80 each, but there is also a little check box for quantity discount, which you can also configure (or is set automatically)... So mine is set at give 10% discounts until it reaches a maximum of 20% and to give discounts at every 10 units. Now, do I feel good about this customer or do I forsee them being a PITA? Do I forsee any problems that can arise? That is usually the difference between me checking that box or not. So lets say I like them, and the job is a breeze - sure I'll check that box - now I'm at $64 each - and this is my price if there is really only 16 minutes of design time...
Lets say all the signs are different... Could it possibly take 16 minutes each to lay these out? Maybe it can, if it really was my job it's likely I could spend at least 16 minutes per sign, but can I charge for all that time because I have a perfectionist mindset? Probably not... so lets say realistically it takes 8 minutes each x 21 different signs, that is an additional 3 hours that you need to calculate for, so I push my slider back up to 3 hours of design time and now I'm at $73 each. So right there I have a range of prices that is all over the map - and where do I adjust the slider to calculate for application tape? Is there any room for the errors (I'm sure I'm not alone) that come up? Does every job go exactly as planned?
Then there is another factor - what will the market bear? Do you offer a better looking product than your competitors? How do you market your business? I don't necessarily sell "signs by the pound" in my shop, everything here is custom - if I outsource a job that can be screen printed or digitally printed, sure I can offer my customers a discount on quantity - but I also CMA on all those jobs and charge for design time on them too. I think there are too many factors for us all to be on exactly the same page. I know NJ is a very expensive place to live and people expect to pay accordingly here (most of the time).
I usually double check my pricing, but I feel pretty ok about Estimate 92.7% of the time... BTW - These are my prices without installation.
Gene
GB2
Old Member
And there you go Gene...there are so many inconsistent variables, how can you rely on the software. I used your version a long time ago and then stopped. When the version 2 came out I thought I'd give it another try and recently I've been taking the time to try to set it up properly in order to get that reliable consistent result but I'm finding it very difficult to have the faith. I think I'm going to have to write my own software with logical formulas to reflect Fred's approach.
Malkin
$62.40 here using our in-house software.
(which includes $58/hr labor, $65/hr setup & 2x markup on substrates)
signmeup
And how did Fred know it would take him 1/2 an hour? A guess.... based on years of experience. Of course, it may take him longer than his guess or less time.
Estimating software will attempt to estimate the time involved too. (could this be why it's called an estimate?) How will you write software that estimates the time exactly right every time?
