white spots in prints
depps74
I posted this in HP forum, but kinda desperate for someone to answer. I am guessing this is a known problem with an easy fix? My HP latex 315 is printing white spots in my images. See pic. Any ideas or help as to why this is happening. I did just replace the optimizer cartdridge. The material I am printing on is 3M Ij35 matte. All my tests so far have spots in them or the ink is muddy looking.
Joe House
Sign Equipment Technician
It still looks like contaminated media. Did you try another media as suggested in the other thread?
rx7boy
Hello we were having the same issue with our hp 360 and IJ35C-20 media. We thought it was the media at first but then we thought it was something in our environment. After lots of tests and different media’s we came to the conclusion it was the media. We have had 2 bad rolls from 2 different suppliers at pretty much the same time but all is good now after we got some newer rolls
depps74
depps74
It was the media. You were right. Now I am getting greasy spots though. especially with dark colors. I increased the interpose delay and heat with fingers crossed.
Have you done a cleaning of the curing tunnel?
Typically greasy spots are due to reduced airflow and heat. If the holes are plugged the air can't wick away the moisture from the latex ink.
JERHEMI
I'm having the same issue with black not drying. Can you explain or point us in the direction of where/how to clean the "curing tunnel"? Thank you!
It is part of service maintenance kit 3, but depending on your print environment the cleaning needs to happen more frequently. you need to disassemble the curing tunnel to clean the airflow plates on the top side, its pretty laborious.
JERHEMI
Is this something that would be covered under a warranty to have a tech come out and handle?
