1" x 3" vinyl decals no lam / rounded corners...how much
gabagoo
This size decal always gets me when I try to price it. Anything 1" or smaller results in very little square footage and not fair to myself to price that way. Is there a way to price such a large quantity of small decals digitally printed properly? I would like to get about $350 for that amount, If I were to do it on the Edge I would charge about $425.00. How do those prices sound?
anotherdog
how many?
I still price on Square feet of vinyl then look at how much knifework and weeding is involved = more heft cutting charge.
anotherdog
you will kill a blade with 1600. even without lam.
I would charge around $300 for the adhesive and at least $80-$100 for the cutting.
maybe even more given the handwork (are you cutting down the 40 ft sheet of vinyl?).
...plus of course the time it will all take to do...
I don't think your $425 is too far off.
We also do other kinds of labels, for a job like this I would be asking if paper labels would do the same job, even uv coated paper. may be a lot cheaper.
gabagoo
Kill a blade? you kiddin me, my Summa on the original blade I got with it 3 years ago. I find if you round the corners everything weeds nicer. This job took maybe 45 minutes to print and may have used 4 or 5 yards of 54" material if that. I dont cut them up into individuals. This one was 7 per sheet.
Browner
Perhaps you have your blade "depth" set too high if you're killing blades that quickly. :help
I'm assuming one color print on intermediate grade vinyl. Pricing anywhere between $0.25 to $0.30 each seems about right, though.
Marlene
sorry, there are 1600 pcs
for that many, I would get them screen printed.
I have an Edge and we sell by the running foot so it is how many fits on a running foot. if it is a small run and falls under the minimum charge, that charge applies. to do this on an edge, you will use about 42' of vinyl. will you weed it? will you cut them apart or sell it as 42' of decals?
S
scarface
Guest
Using graphix calc, I'm coming up with $.19 each ($304) on 3651.
Looks like your using about 17.25 running feet of 30" material and 44 (rounded up) square feet total. At $304 your getting about $7 psf
Signcraft is saying $6.76 psf so I'm right on the money IMO.
On the small stuff, You need a shop minimum. I try to push $25 as my minimum alot. That's low but it still keeps people interested for us small shops.
gabagoo
We have an Edge but this baby was run through the Mimaki. Printing is pretty fast and we cut them down into strips of 7, so you get about 228 strips and then we heat seal them in plastic tubing. I don't think I would send anything like that out for screen printing as the $$ I make at the end just don't seem worth it. Keep it inhouse and I can control it.
anotherdog
Perhaps "kill" was the wrong word. It takes the edge down, I have a couple of blades on the go. I use the newest for fine detail cut letters and the oldest for grinding out laminated decals.
I figured it at around 40 sq ft. with some waste.
Did you weed them?
Tim Aucoin
Inkjet print & cut (on Roland) on 3M IJ3510, I'm in at $325.50... if they want them cut individual, I'm at $452.07.
Thermal print & cut (on Gerber), I'm at $413.50... $530.69 if cut individual.
These prices are out of Estimate Software.
I have a $40 shop minimum for anything that touches either the Roland or Gerber. :rolleyes:
Merry Christmas!! :smile:
S
scarface
Guest
How are you guys figuring out how much to charge for separating graphics? Pretty much every job requires this of bulk orders i would think. My software is at $1.00 PSF for separating and i think that's too low
