Techman
how 4 holes to drill.....
think about it.....
Then you have 100 grommets to install.
Installing grommets in my post means poking the holes too.
think about it.....
No way this is done in less than 4 hours.
quote]
here you go with assumptions.
Just because your way would take you 4 hours doesn't mean it would take everyone that long.
this is a simple job. in a well equiped shop this job can be done quite rapidly, I would agree that if you are shearing these with a small table shear, setting grommets wiht a punch in a minimum of working space on your kitchen table you'd be lucky to get it done in 4 hours.
"IF" I ordered the aluminum in sheet form (4X8) doubtful when these are available of the shelf, they can be routed to size, shape, and with the grommet holes literally as fast as I can clean take off the piece that just got done being routed, the next one is done, 040 is like butter.
regardless of the methodology we used for the graphics depending on the complexity of hte artwork, vinyl or screenprint, it is rapido, setup some jigs or registration marks so that no measuring is necessary
setting the grommets with grommet machine versus hand punch less than 30 seconds (way less) to do all 4 in each sign
i guess i forgot the time to write the thank you letter to the client for sending me a gravy job
Are we just shooting the breeze with each other because we can’t see each other and don’t care ??
are we all just wasting our time ??
sorry,, I don't agree with these time assessments at all.
I'll give ya some credit for time. That takes it down to 3.5 hours under ideal conditions. Order taking, materials ordering, set up, clean up, all of it takes time and must be accounted for.
Only a few shops have a router table. Even fewer have a router table and jigs ready to go for this. I can't understand why someone would use a 50 grand machine for a stomp shear anyway. A nibbler would do the corner rounding on this much faster and cheaper. So if one wants to talk about a well set up shop then a nibbler would be there long before a router would be.
If you would base most of you’re pricing structures with your posts, you guys are charging anywhere from $12.00 an hour to $378.00 an hour, based on how you feel on any particular day.
: Soooooo......... what are you honestly getting for the entire job ??
