Awnings are simple structures..... you build and aluminium frame and then staple a fabric covering onto it.... it's not rocket science.
This awning company is deliberately trying to add on layers of complexity which just aren't there..... the original awning blew off the building because it wasn't fitted properly.... you can see this just by looking at the photographs.
Siting vehicle impact is a complete Red herring.... there is no sign of impact damage on the framework and the fabric covering is virtually undamaged. In a vehicle strike situation these aluminium framed awnings crumple and collapse in a major way.
All it takes is for one section of awning to be installed with too few fixings and the wind will work it loose.... once the first section is free it will drag off other connected sections with ease.
If you can find some of the screws used to fit the awning you'll soon see whether it was fitted properly.... on something that size you would expect aluminium hooks every metre and at least 75mm long screws in between the hooks... the hooks should also be connected to the awning frame with large guage self tapping screws. The vertical support legs also need to be firmly bolted to the wall... if not the wind gets underneath the awning and flips it up over the hooks... snapping all the screws as it does so.
Awnings are simply SAILS in another format... whenever you build and install an awning structure you are basically bolting a sail onto the side of a building.... if it's not nailed on in an over engineered fashion even moderate winds will peel that sucker off in seconds.
We used to make a lot of awning and canopy structures in years gone by.... what Heath is experiencing is a classic example of a poorly fitted awning or an awning which has been tack fitted temporarily in the expectation of revisiting site to install the permanent fixings.
In this case it's not your problem and it's NOT an insurance issue... the awning company installers f*cked up and it's their responsibility to fix the problem... if this costs them a boat load of money then it's tough titty.... it'll teach them to install properly first time, everytime.
