Anyone know why one of the dampers (damper number 4 which is black) wont fill up after replacing the whole head?
hamedsalehi1
So i just fully replaced the second head of the CJV300 and connected all the tubes properly from 1-8, they all filled up and worked perfectly fine when I tested them with a test print no issues! But for some reason one of the blacks doesn't work and it doesn't fill up no matter how much I tried pulling it in even using a syringe making sure its flowing properly from the tube into the head but it still doesn't print whatsoever. Anyone have experience with one of the colors just not printing at all after a replacement or some sort like that.
Attached a picture of the test print results.
dudeinthemoon
The damper is probably damaged, this happens sometimes with the new dampers. Make sure the printhead is not clogged, with the syringe and replace the damper if no clogs
budlinch
This happened to me too. I replaced a new damper with a new damper and it worked. The first new damper must have been damaged.
REFLEXUSA
realistic independent outside-the-box thinker
sometimes themanifold inlet gets clogged, not usually with black, but i suppose all things being equal, if given the chance to it would.
DL Signs
Never go against the family
You need to gently squeeze the sides of a new damper for initial fill. Best way I've found is to open the valves for that color, fill the damper (do it over a container to catch excess ink), close the valves and insert it into the head.
SignSlob
When installing new dampers, you usually have to "prime" them. On my model (1800z) this is done by attaching the damper to the ink lines and using a small syringe on the bottom "nipple" to draw out the air thats inside it until ink flows steady. But a bad damper out the box isnt out of the question.
Good luck!
REFLEXUSA
i guess because its harder to actually see whats in the black.
plus black is the strong color, its more porous than white is , in most varieties.
ive had more clogs with white, cyan , magenta, than with black and yellow.
