Bulk Ink Mutoh VJ1624
darkorical
I have been looking to change my 1624 to a bulk ink system and found the ZMY-08906 bottles and cartridges. According to the info I found on Digiprint's website http://www.digiprint-supplies.com/mutoh-bulk-ink-system-4-bottles-4-cassettes-zmy-08906.html and the information I received from Nazdar regarding their ink https://sourceone.nazdar.com/P/4099/Nazdar-2100-Solvent-Inkjet-Ink it should work just fine in my system. BUT when I talked to Mutoh they told me that that bulk ink system was only for Dye-Sub inks.... then the guy told me that many companies in central America use the printer with that BIS with out issue. So I'm really wanting to believe people and switch because right now I'm using a full set of OEM 440 carts every few weeks, and the savings would be huge. BUT the last thing I want is for the ink to melt the BIS and leave me with 4 liters of ink to clean up not to mention out nearly $1000 to boot. Can anyone here shed more light on this?
FatCat
We put a Bulk system on our 1624 the day we got it last November. It has never run OEM ink. We use JetBest ink and a Knight bulk system, you have to buy cards and replace them, but the savings over OEM are huge.
MagnetStew
I second FatCat. All our Mutoh's are on the Knite Bulk Ink System. We also bought a smart card charger along with the smart cards/codes from sovlentcartridges.com. JetBest has good prices on bulk ink and the ink works great. No issues.
darkorical
has anyone actually used the BIS I referenced I am drawn to it as it is actually manufactured by mutoh and does not seem to need extra cards to reset the chips
premiercolour
We have Bordeaux branded for Mutoh Valuejet printers - 1L ink bag, 1L ink bottle and 440ml complete cartridge with chip in stock to ship from s. California. Bordeaux ink is one of the top three most sold eco solvent ink in USA. Buy with confident. Call us for more information or questions. 714-668-9200.
http://www.premiercolour.com/inks-for-mutoh-2/
0igo
hey where did you get your bulk ink supply from?
FatCat
http://www.ebay.com/itm/Bulk-ink-su...179369?hash=item2a374955a9:g:1GcAAMXQVT9S7wtC
Best price I found - just ordered a new one last month for our new 1624X, arrived in about a week or so...
We opted for the new style "direct tubing" cartridge, which basically is just an ink line running though the cartridge into the needle valve, so it's basically like extending the line from your printer with no mess or fuss with the old style float cartridges.
premiercolour
Bulk Ink for Mutoh Valuejet
This is the most used bulk ink system for Mutoh printers. You can have the machine up running in 20 minutes. Direct feed line is great; just there are many lines to figure out. These will work just like OEM ink cartridge except you refill through a funnel. 2 days shipping via Fedex ground. We ship daily from S. California. Use same color profile from Mutoh Eco ultra ink, plug and play. No need to mess with flushing or purging if you are switching from OEM. Customer service is always there for our customers. Reference is always available on all Mutoh eco solvent printer models.
http://www.premiercolour.com/special-bulk-ink-system-for-mutoh-valuejet-1204-1604-1614/
Customer Service
Premier Colour, Inc
949-209-7306
0igo
hey for your ink cards do you reload them or do you buy new cards everytime?
premiercolour
Smart Card
Smart card is not re-loadable. Customer needs to buy smart card every 440ml ink usage or there is a way to prolong the life of the smart card up to approx. 3,000ml of ink usage.
http://www.premiercolour.com/mutoh-smart-card-for-1204-1304-1604-1614-2606/
Ink customer pays $10.00 per smart card.
The four refillable cartridges, four liters of ink cmyk, eight smart cards with shipping $450.00. It is all you need.
Francis
Umca
I am used Bulk Ink system with charged smartcards also. But I found most cheaper solution.
I am purchased service code for permanent disable smartcard system of printer and use now third-patry ink without any cards on my VJ1624 and VJ1638 printers within 2 years.
FatCat
Yes, we buy new smart cards - JetBest charges $7/ea. Would love to find an easy way to disable the chip reader...
heyskull
When you install new cards.
Set a print of and whilst it is printing remove the cards and install an old set.
You will never need to buy cards again, or until the cards go out of date.
Just as long as you do not turn the machine off but they stil work if you put it in sleep mode.
I am running a set which were new in december 2014 and still all showing about 80%
SC
Umca
SC
I think this method can be used for old generation of ValueJet (1203-1304-1604-1614)
But 1624 and 1638 has another logic for smartcard system.
heyskull
I stand corrected.....lol
Typical, Mutoh trying their hardest to lock us into using only their overpriced ink.
I am also using Jetbest on my 1604 and 3 years on the same print head and zero blocked nozzles.
SC
bug
i had origiinal bulk system from mutoh with their ultra mild solvent ums ink, after 10month i needed to replace head, cyan dead, i used around 20 litres in this time
mutoh did replace it free of charge, but anyway i decided to change with bag ink supply i think its closest to ink cartridges and with bordeaux ink eco solvent, ill see what happens
premiercolour
Premier Colour Inc from S. California is one of Bordeaux's premium dealers. We have the 1L ink bag, and adapter in stock for your Mutoh printers. Same color gamut, as good as OEM. Print with OEM ink cartridges.
http://www.premiercolour.com/bordea...nd-chip-for-mutoh-valuejet-printer-eco-ultra/
http://www.premiercolour.com/mutoh-valuejet-1000ml-ink-adapter-adapter-only-ink-sold-separately/
http://www.c-m-y-k.com/product/fuze-eco-mt/
Sincerely,
Premier Colour, inc
714-668-9200
