cable size for over the street banner?
Big House Signs
We are doing an over the street banner for the 25th anniversary of our Boys and Girls Clubs. It is 3ft high x 24ft wide, using 16 oz banner with webbing, d-rings on each corner and grommets every 2 ft to use snap hooks to cable. I have googled and googled to find exactly what the correct hardware to use. I have found lots of city ordinances of what they require. One suggested 3/8" cable. Is that correct?
Any direction or information is greatly appreciated.
Thanks,
Paula
OldPaint
3/8" steel cable???? or 3/8 rope?
i can tell ya real quick the steel cable that size is what is on most truck wenchs)))))
I have 2 steel cables holding up my 8' X 24' loft in my garage. each 1/4" cable is rated at 2000 pounds.
http://www.engineeringtoolbox.com/wire-rope-strength-d_1518.html
wind load is what is gona be your concern. ill put it this way, 3/8" steel cable would be able to hold up to a cat 3 hurricane)))))
Desert_Signs
How long does the cable need to be? What are the attachment points? If it's light poles, make sure they're rated for the additional sideload. I passed on a job like this due to the light poles not being designed for additional sideload. Another shop took it on. Both poles bent over 3" just during the installation trying to make the cable taut. They had to give up and pay to repair the poles.
At any rate, if your span is reasonable (30-40'), 3/16" cable should be fine. You coud get away with 1/8", but you're going to have some sag.
Big House Signs
Yea...I thought that was mighty big!
Mosh
Does your City know you are doing this? Are the pole strong enough if there are high winds? I would just hand them the banner and tell them to install. Way too much liability here. Happened here in our town, we had a wind storm come in and it damaged one of the poles/lights. Thankfully the city crew did the install, or my goose would have been cooked.
Billct2
This is not something I would want to be responsible for.
Either the city provides the specs and assumes responsibility in writing (even with that you'd be named in the lawsuit) or I'd pass.
I'd probably pass anyhow.
CanuckSigns
Our city has specs that have been stamped by a engineer that all banners must be made to. The banners are installed by city crews for liability reasons. I would check with the city about exactly what they want.
i've attached our city's specs to give you an idea
  • Banner Specs 2011.pdf
Big House Signs
The city told the Boys and Girls Clubs they could put it up. Infact the sign says the City congratulates them on 25 years. But Comcast is actually doing the install. I just need to come up with the banner and all the right hardware. I dont even think the city has specs for over the street banners.. It is very Mayberry RFD here. Thanks for everyone's help!
Paula
Bretbyron
In our City you have to talk to the "City" first, they contact CalTrans and clear it with them then the city hangs them. CalTrans is the one that has the banner hanging requirements and codes.
Rocco G
Paula
Engineers tend to overbuild. One recently asked us to install some channel letters with 1/2" SS threaded rod, four per letter then backed up with 2" x 2" x 1/4" steel angle each spanning two studs. This was for 24" letters INSIDE a mall with no wind load, eight feet above the floor. That city spec stating 3/8" cable was prob done by an engineer. The lifting cable on my crane is 3/8" IIRC.
HOWEVER, if the city has a spec that calls for 3/8" cable, then you should spec 3/8" cable. Or call an engineer and get stamped plans. I would also specify that the cables be attached to a building, not poles. In reality 3/16" should be fine, but better safe than sorry.
And no, you cannot get it completely tight and straight. It will sag no matter what. Pull it too tight and it will either snap or start pulling over what it's attached to.
SOLO_Fab
Hustler
I know this post is old but might as well ask here than start a new thread. I have a client that wants a cable stretched across 150' so he can have banners attached to it over a bunch of golf simulator bays. I was thinking about a 3/16" vinyl coated cable stretched taunt with some beam clamps and turnbuckles. Does this sound legit or due to the length should the cable be thinner/thicker?
You'll never stretch a cable 150', hang banners on it and not sag quite a bit. You'll need to put some sort of bracing every 35' or 40' and then you'll have a slight chance of it not looking too bad. Kinda how window treatments work.
it certainly should not be thinner
SOLO_Fab
Hustler
So there isn't anyway to keep it taunt unless I brace it every so often like every 40'. My thought would be to brace from every support beam from either end like what I show in the picture attached?
SOLO_Fab
Hustler
I guess I could stretch a cable from top beam to beam and then come down with 2 cables to attach each banner to, the banners are 4'w X 6't. What would you guys do in this situation? Customer is selling sponsorship over each bay so there needs to be support over each bay to hang a banner and randomly change them out.
Use the lightest weight material you can find and give it a whirl. If they're 6' wide, you'll fit maybe 23 or 4. With 4' wide maybe 35
Weigh a banner and multiply by however many banners you're making and do the math.
SOLO_Fab
Hustler
There will only be 10 max
