What’s easier to work on ? I’m comparing all this to a valuejet 1204 that I hated doing work on.Not a helluva lot of difference between Roland and Mutoh on old DX4/5/7 head machines when it comes to things like parts to be honest. Older printers as well, expect to need more maintenance overall.
we have had a roland sc545-ex since 2016Now the big question is. I’ve always had value jets and did nothing but work on them trying to keep working properly. Anyone have both or had and how do they compare for repairing and replacing stuff like this and lines maintenance stations etc. are they similar or completely different. Are the Roland’s truly more resilient?
Agreed. For a comparison of simplicity vs engineering complication, look at the DX7 ink line to damper connection of Mutoh vs Roland. I absolutely detest the Mutoh part. I'm starting to suggest my Mutoh customers switch to the Roland version during a head replacement. Mutoh - stuff needed - needle nose pliers, new O-rings for ink line nut and patience for the PITA factor to remove it. Roland - stuff needed - finger and thumb, push ink line onto barb fitting, push adapter down on damper until it click locks. Squeeze click lock to remove. Easy peasey... Done...we have had a roland sc545-ex since 2016
go a vj1617h about 2.5 years ago
i find the rolands very easy to work on. (i am a former tech, though)
i still struggle to understand what was in the mutoh engineering team's head, when they made some of their decisions.
i wouldn't be afraid of the roland. i say go for it!
Thank you. This helps me to decide on going with the Roland.Agreed. For a comparison of simplicity vs engineering complication, look at the DX7 ink line to damper connection of Mutoh vs Roland. I absolutely detest the Mutoh part. I'm starting to suggest my Mutoh customers switch to the Roland version during a head replacement. Mutoh - stuff needed - needle nose pliers, new O-rings for ink line nut and patience for the PITA factor to remove it. Roland - stuff needed - finger and thumb, push ink line onto barb fitting, push adapter down on damper until it click locks. Squeeze click lock to remove. Easy peasey... Done...
all very trueAgreed. For a comparison of simplicity vs engineering complication, look at the DX7 ink line to damper connection of Mutoh vs Roland. I absolutely detest the Mutoh part. I'm starting to suggest my Mutoh customers switch to the Roland version during a head replacement. Mutoh - stuff needed - needle nose pliers, new O-rings for ink line nut and patience for the PITA factor to remove it. Roland - stuff needed - finger and thumb, push ink line onto barb fitting, push adapter down on damper until it click locks. Squeeze click lock to remove. Easy peasey... Done...
I always thought. “Could they make it any harder to work on this thing !” With my 1204we have had a roland sc545-ex since 2016
