News DIY Flatbed Laminator Project – A Maker’s Journey
V-Pixel
Flatbed-Applicator Maker
Hey everyone,
after working in the signmaking world for quite a few years, I finally decided to tackle something that’s been bugging me for a long time — building my own flatbed laminator.
Why?
Because every time I looked at the commercial options out there, I couldn’t shake the thought:
“That’s a lot of money for what’s basically a frame, a roller and some pneumatics.”
My background is actually in mechatronics and industrial R&D, but I’ve always had a soft spot for hands-on signmaking and vinyl work. In my small workshop, space and budget are limited — so the idea was simple:
Build a professional-grade flatbed laminator that’s compact, modular, and affordable.
The project — which I call SignSystem 1320 — took about a year of spare-time development:
lots of CAD modeling, test builds, and adjustments.
It’s based on standard aluminum profiles, precision linear rails, and a custom-made silicone roller.
I also integrated pneumatic lift controls, LED backlight, and optional features like a roll holder and mesh catch tray.
Here’s what I focused on:
  • Solid construction, not a wobbly frame
  • Smooth and synchronized roller movement
  • Easy-to-service pneumatic system
  • Modular add-ons like lighting and storage
  • A clean, professional look that fits any shop
After many hours of testing, the system works great — and it performs just as well as many commercial units.
I’ll share photos, renders, and some behind-the-scenes progress in the next posts.
This build might be interesting to anyone who ever thought about building their own equipment or optimizing their workflow without spending 6 - 10K+.
Happy to hear your thoughts, feedback or maybe your own DIY equipment stories!
Cheers from Germany
Manuel
  • Informative
Reactions: 1 users
V-Pixel
Design Challenges & The First Deliveries
During the design phase, I spent a lot of time studying existing laminator systems — not to copy them, but to understand where they fall short.
One issue stood out immediately: the roller guidance.
Many well-known manufacturers rely on rather shaky systems and then include long manuals on how to “adjust” the roller alignment.
That was not an option for me. I wanted it precise and smooth from day one, so I went with CPC precision linear guides.
They’re definitely more expensive, but the result is night and day — the roller moves perfectly aligned and completely play-free.
At the same time, I was sourcing parts from different suppliers.
Since I don’t have a full metal workshop, I ordered all aluminum profiles pre-cut and machined directly online.
And then came the fun part — the first shipments arrived, and the actual build finally began.
V-Pixel
From Concept to the First Build
Once the design felt solid enough, I started with the actual build.
In the beginning, it was more of a testing playground — I printed many of the early parts on my 3D printer just to validate ideas and fitments.
That approach turned out to be a big win.
It allowed me to test different concepts, tweak dimensions, and refine the overall setup without burning through expensive machined parts.
Only after everything worked as planned did I order the final CNC-milled aluminum components.
The transition from printed prototypes to real metal felt incredibly rewarding — it was the moment when the project started to look and feel like a real machine.
V-Pixel
The Big Parts: Lighting, Pneumatics & the Roller
Next came the bigger components — LED backlight, pneumatics, and of course, the roller installation.
The roller itself is built to last: a heat-vulcanized silicone coating, non-stick and extremely durable.
It’s the heart of the whole system, and seeing it mounted for the first time was a real milestone.
For the pneumatic and control unit covers, I used 3D-printed housings.
They’re affordable, easy to reproduce, and honestly feel surprisingly premium once assembled.
The catch basket underneath is a simple but effective idea — basically mesh fabric, printed with my logo and mounted to round aluminum profiles.
I also made sure most of the round parts were identical in length, to keep the build as efficient and clean as possible.
grundrahmen5.jpg grundrahmen9.jpg grundrahmen8.jpg grundrahmen7.jpg grundrahmen6.jpg
V-Pixel
The Final Build — and What Came Out of It
That’s pretty much the end of the build story.
Along the way, I also created full pneumatic and electrical schematics, so at some point the documentation became detailed enough to turn the whole thing into a proper DIY project - SignForgeX.com.
The table may be mobile, but it’s a solid piece of equipment — heavy enough to stay perfectly stable, and in my opinion easily comparable to commercial systems.
Control is intentionally simple: manual lever valves for precise operation, plus a blow-off pistol for cleaning and prep work.
The roller pressure can be adjusted independently, giving full flexibility for different applications.
And here it is — a few renderings of the finished machine.
Seeing it come together after months of design, testing, and tweaking was incredibly rewarding.
  • I Appreciate You
Reactions: 2 users
StephenOrange
Eater of cake. Maker of .
Mate, what a proper setup! I've often imagined building my own but nowhere near the quality of this. I'm very surprised by the custom made roller especially given all the other stock materials you utilised.
CAWW
The Swedish Rollsroller is the standard, take engineering principles from this masterpiece. If you haven't already.. cheers and good luck.
V-Pixel
Thanks a lot, really appreciate it!
The roller was actually the only custom-made part — everything else is built from standard aluminum profiles and off-the-shelf pneumatic components.
That was one of my main goals: make it possible to reproduce without special machinery.
I ended up documenting the full process once I saw how well it worked — turned out way better than I first expected!
Congratulation on your build. innovation is still alive.
Thank you Johnny
that's pretty wild. What kind of money do you figure you have into the build?
Thanks, appreciate it!
All in, the project came to around €4,300, including the custom roller, pneumatics, and precision rails.
I’ve listed a rough cost breakdown and the full specs here if you’re curious: signforgex.com/spezifikationen.
Still way below what most commercial systems cost — and honestly performs on the same level.
Thanks a lot!
Absolutely — the Rollsroller was definitely one of the key references when I started designing the system.
I tried to take the solid engineering principles behind it and adapt them into something more modular, compact, and DIY-friendly.
Best regards
Manu
V-Pixel
First functional test – laminating a 3 mm PVC sheet with Printed Vinyl.
The roller pressure was set to 3 bar, resulting in a clean, uniform bond across the entire surface.
No bubbles, no wrinkles – exactly what I was aiming for.
