News DIY Flatbed Laminator Project – A Maker’s Journey
V-Pixel
Flatbed-Applicator Maker
Hey everyone,
after working in the signmaking world for quite a few years, I finally decided to tackle something that’s been bugging me for a long time — building my own flatbed laminator.
Why?
Because every time I looked at the commercial options out there, I couldn’t shake the thought:
“That’s a lot of money for what’s basically a frame, a roller and some pneumatics.”
My background is actually in mechatronics and industrial R&D, but I’ve always had a soft spot for hands-on signmaking and vinyl work. In my small workshop, space and budget are limited — so the idea was simple:
Build a professional-grade flatbed laminator that’s compact, modular, and affordable.
The project — which I call SignSystem 1320 — took about a year of spare-time development:
lots of CAD modeling, test builds, and adjustments.
It’s based on standard aluminum profiles, precision linear rails, and a custom-made silicone roller.
I also integrated pneumatic lift controls, LED backlight, and optional features like a roll holder and mesh catch tray.
Here’s what I focused on:
  • Solid construction, not a wobbly frame
  • Smooth and synchronized roller movement
  • Easy-to-service pneumatic system
  • Modular add-ons like lighting and storage
  • A clean, professional look that fits any shop
After many hours of testing, the system works great — and it performs just as well as many commercial units.
I’ll share photos, renders, and some behind-the-scenes progress in the next posts.
This build might be interesting to anyone who ever thought about building their own equipment or optimizing their workflow without spending 6 - 10K+.
Happy to hear your thoughts, feedback or maybe your own DIY equipment stories!
Cheers from Germany
Manuel
  • Informative
  • First Place
Reactions: 3 users
V-Pixel
Design Challenges & The First Deliveries​
During the design phase, I spent a lot of time studying existing laminator systems — not to copy them, but to understand where they fall short.
One issue stood out immediately: the roller guidance.
Many well-known manufacturers rely on rather shaky systems and then include long manuals on how to “adjust” the roller alignment.
That was not an option for me. I wanted it precise and smooth from day one, so I went with CPC precision linear guides.
They’re definitely more expensive, but the result is night and day — the roller moves perfectly aligned and completely play-free.
At the same time, I was sourcing parts from different suppliers.
Since I don’t have a full metal workshop, I ordered all aluminum profiles pre-cut and machined directly online.
And then came the fun part — the first shipments arrived, and the actual build finally began.
V-Pixel
From Concept to the First Build​
Once the design felt solid enough, I started with the actual build.
In the beginning, it was more of a testing playground — I printed many of the early parts on my 3D printer just to validate ideas and fitments.
That approach turned out to be a big win.
It allowed me to test different concepts, tweak dimensions, and refine the overall setup without burning through expensive machined parts.
Only after everything worked as planned did I order the final CNC-milled aluminum components.
The transition from printed prototypes to real metal felt incredibly rewarding — it was the moment when the project started to look and feel like a real machine.
V-Pixel
The Big Parts: Lighting, Pneumatics & the Roller​
Next came the bigger components — LED backlight, pneumatics, and of course, the roller installation.
The roller itself is built to last: a heat-vulcanized silicone coating, non-stick and extremely durable.
It’s the heart of the whole system, and seeing it mounted for the first time was a real milestone.
For the pneumatic and control unit covers, I used 3D-printed housings.
They’re affordable, easy to reproduce, and honestly feel surprisingly premium once assembled.
The catch basket underneath is a simple but effective idea — basically mesh fabric, printed with my logo and mounted to round aluminum profiles.
I also made sure most of the round parts were identical in length, to keep the build as efficient and clean as possible.
grundrahmen5.jpg grundrahmen9.jpg grundrahmen8.jpg grundrahmen7.jpg grundrahmen6.jpg
V-Pixel
The Final Build — and What Came Out of It​
That’s pretty much the end of the build story.
Along the way, I also created full pneumatic and electrical schematics, so at some point the documentation became detailed enough to turn the whole thing into a proper DIY project - SignForgeX.com.
The table may be mobile, but it’s a solid piece of equipment — heavy enough to stay perfectly stable, and in my opinion easily comparable to commercial systems.
Control is intentionally simple: manual lever valves for precise operation, plus a blow-off pistol for cleaning and prep work.
The roller pressure can be adjusted independently, giving full flexibility for different applications.
And here it is — a few renderings of the finished machine.
Seeing it come together after months of design, testing, and tweaking was incredibly rewarding.
  • I Appreciate You
Reactions: 3 users
VizualVoice
that's pretty wild. What kind of money do you figure you have into the build?
CAWW
The Swedish Rollsroller is the standard, take engineering principles from this masterpiece. If you haven't already.. cheers and good luck.
V-Pixel
Mate, what a proper setup! I've often imagined building my own but nowhere near the quality of this. I'm very surprised by the custom made roller especially given all the other stock materials you utilised.
Thanks a lot, really appreciate it!
The roller was actually the only custom-made part — everything else is built from standard aluminum profiles and off-the-shelf pneumatic components.
That was one of my main goals: make it possible to reproduce without special machinery.
I ended up documenting the full process once I saw how well it worked — turned out way better than I first expected!
Congratulation on your build. innovation is still alive.
Thank you Johnny
Thanks, appreciate it!
All in, the project came to around €4,300, including the custom roller, pneumatics, and precision rails.
I’ve listed a rough cost breakdown and the full specs here if you’re curious: signforgex.com/spezifikationen.
Still way below what most commercial systems cost — and honestly performs on the same level.
Thanks a lot!
Absolutely — the Rollsroller was definitely one of the key references when I started designing the system.
I tried to take the solid engineering principles behind it and adapt them into something more modular, compact, and DIY-friendly.
Best regards
Manu
Reactions: 1 users
V-Pixel
First functional test – laminating a 3 mm PVC sheet with Printed Vinyl.
The roller pressure was set to 3 bar, resulting in a clean, uniform bond across the entire surface.
No bubbles, no wrinkles – exactly what I was aiming for.
V-Pixel
Been thinking about your build and I have a few thoughts/questions?
- any possibility of extending the bed in order to take a full 8 x 4 sheet, even if there’s some waste involved. Perhaps even longer (eg: long enough to cater to a 3000mm sheet) too utilise any additional build material?
- what was the technical reason for shortening the width of the roller to below 1370mm+ wide? I realise most rigid substrates will fit within this width but most print media is 1370mm, so you would need to trim all media down before mounting?
- has the simple bar method been OK to hold app tape, prints, lam etc? Would an option to place mounting media onto a spindle carry some benefit in some circumstances?
- would a manual version be in the works or possible for an even more budget friendly option?
Still, savage setup you’re selling!
Hi Stephen,
Thank you for taking the time to look at the design and for your thoughts.
Regarding your questions:
- There are two options for accommodating an 8 ft panel: either a “simple” extension could be offered as an option, in which case the panel would lie flat but could only be covered by a maximum of 1.9 m in length by the roller. The second option is to move the bridge upwards, which would allow the table to be adjusted as desired without requiring a great deal of effort.
- To be honest, there is no technical reason for the 1300 mm width. The main reason is that I initially manufactured the laminator just for myself. Since I only sell plotter material, I didn't even notice the width of the printing foils – but changing this would be a minor matter.
- Regarding the holder, do you mean the side holders or the roll holders above the laminating roller? If you mean the second one - I only have experience with transfer tapes here, but since the holder can be fully adjusted in position, the roll of transfer tape usually rests against the roller, which ensures stability - but I am also in the process of designing a centering cone and will test it soon.
- Sorry, what do you mean by manual version?
Thank you and best regards
Manu
V-Pixel
I am strongly considering purchasing your system plans, hence the questions.
- I would really want the table to be able to be able to fully mount at least a 2440mm long board, so an extension, though a quick fix, would become cumbersome in the long run. Without going into details and wasting your time, will this be possible with your build?
- would love a wider roller, but this isn't a massive issue as loose sheet mounting needs to have the prints removed from the roll so a quick half-arsed trim will do the job
- Yeah, I meant the top roller. I get what you mean by it resting against the roll. My usage for the table will be far more focussed on panel mounting
I'll get in touch via your website closer to the time. Thanks for the feedback, and kudos again for the detailed build!
Hi Stephen,
First of all, apologies for only responding now.
I've been thinking about how I can implement your request in a reasonably flexible way.
Over the last few days, I've created a table size configurator. This allows you to enter three parameters (table length, width, and height), and the rest is then generated automatically—including the 2D drawings.
The whole thing is implemented in Excel and is now included as standard in the “basic structure” package:
For a 2440 mm board, you need a 2680 mm table surface (120 mm must be deducted from each side of the table) – unfortunately, I cannot guarantee this with the current design. I suspect that a redesign will be necessary for this. I will get back to you.
Best regards
Manu
Valman
Hello! Would you be willing to share your experience and drawings, and under what conditions? I don’t have a lot of money for a RollsRoller either, but I do have a cutter, a two-roller laminator, a compressor, a pair of hands, and the motivation to give it a try =)
