Need Help edge fx pausing during printing
barbotte
hello first post here and new to Gerber edge (hobbyist) i did read 20 page of forum and could not find a solution here is my problem ... edged fx omega 6.5 ...stand alone dell (no internet ) with window 10 been printing small stuff for few month and now i have a 4x4 ft project and the problem is every 1 ft or so the printer stop/pause but the foil tray keep moving-rolling ..sometime it stop for 1 or 2 second most time or so long that I Actually have to pause it ( or waste the hole foil running ) tray lift up ,,,then put it back online to continue printing but when it does it make a line like its missing print . i did try the 3 colour mix or the solid one and still does it i try to change the dpi to 600 and 1200 and its worse it does every 6 to 9 inch is there something in set up that i not doing ? i put some picture so easier to understand thank for your help
barbotte
no internet here, direct connection to the laptop I thought about the cable too but replace it with a 4 ft one and still the same. It does sound like memory or data transfer as sometime it take a while to get it to print (it would said online on the edge but noting move sometime up to a minute before anything happen .. does it sound like the print head data cable ?? thank for your input
ky10ww
Hi. Did you figure out the issue? I am having this same issue and would love to know what fixed it. Thanks!
gabagoo
Isn't that a clutch thing? I sort of remember mine doing that. It runs foil but does not print. Honestly can't remember the fix.
Attila Nagy
Most of Gerber Edge and Envision faults linked to Loose cable connections or damaged cables. Try clean and re-seat connectors to the mainboard. Might not a permanent fix, but see if fault goes for a while.
GregLove
I think it may be some sort of communication issue. It's happened on two separate Edge FX printers now. The foil stops advancing, but it sounds like something inside (I think the clutch) continues spinning. After anywhere between 5 and 60 seconds, it carries on printing as normal, most of the time with no defects.
I've already tried multiple network cables, and removing and reinstalling the composer/gsp plot software. Before stripping the Gerber down and attempting to clean the mainboard connectors, I'm going to try using a different laptop to see if that makes any difference. I'm not particularly confident opening it up and cleaning the mainboard connectors as I don't have any experience doing that.
Again, any further advice would be greatly appreciated, thanks everyone.
dynaminator
Mine has always paused occasionally for a few seconds and then just carries on. Not much more than 10 seconds though and usually just a few.
