How can i replicate this text warp?
njsignguy
(Amazing)
I have flexibasic and have adobe cs3 package.
I cannot seem to find something that will make the text like this.
Anyone know?
Thank You
In adobe illustrator cs3, go to effect > illustrator effects > warp > Arc Lower
expand appearance once you have the right "bend" you're looking for and go to Object > Path > Offset Path to generate the white box around the lettering.
Locals Find!
You can do that with illustrator using the type on path tool for the curve.
Start with oblong circle to get the right shape and then use the type of path tool to type out the text and convert to outlines.
For the outline you would select the text you just outlined. Then go object ---> path ---> offset path.
Play around with your setting till you get it right.
yeah, but type on a path also rotates the letter... his example shows a "flat-top", requiring the "Arc Lower" option.
