How much Wholesale
Drip Dry
I doing some wholesale work for a company that installs window tint.
They have me cutting 4' wide strips made up of 1 1/2" squares spaced
1 1/2" apart.
They need 96 strips.
They supplied me the material but I need to cut it down from a 48" roll to
fit it into my 30" plotter. We also need to create the file as well.
We already cut 40 strips. It took about 4 hours total which included time to do the setup. I calculated that we will cut a total of 80 sq ft. ( I think)
Question is: does anyone have a way to price this ?
I'm not sure if I should charge by the sq footage I cut or maybe an hourly charge ?
Any thoughts
ChiknNutz
Personally, I simply charge a percentage off of retail for wholesale/sublet work. Currently, I deduct 30% for cut vinyl and 40% for digital print when selling to another shop for resale.
Drip Dry
I usually charge by the running foot that I supply and then discount it for wholesale, but now they supplied it and I have to handle it by cutting it down to size. They have a tendacy to give me small scrap pieces, so I have to keep loading the cutter.
So, what should I charge?
I'm thinking square footage... maybe $4.00 a square ?
I don't know
high impact
Kinda sounds like something I would have liked to have worked out BEFORE I started the job.
A situation like this usually never works out for anybodies good. I'd simply charge enough shop time to justify the time you have in it and make some profit on labor...although, FYI shops require profit on the material side also to stay in business. You could add what your markup would have been on the material IF you had provided it?
Drip Dry
I almost always do, but this company is always in a rush. I have'nt done a job that he didn't need today. I keep telling myself... this is the last time I'm doing busisness with him, then he calls and guess what... I'm rushing again. Maybe this will be the last time.
have you ever cut tint before?
I never cut tint before, but this is 3m Scotchcal, dusted crystal.
This is all we cut for him. It cuts and weeds well. But I do have to cut it by hand to get it to fit into the plotter.
Rodi
How much is your cost for one person on a shift and a half (roughly) to cut and the setup of the file to cut? How much do you need to make, to make it worth your while? I think the downside to this is that you are being rushed on a commodity job, and that is hard to figure out what the pricing should be. Speed, Quality, Price, pick any two.
Typestries
Please, don't cut it by hand to put it in the plotter. Put the roll in your power mitre box saw and cut the entire log of material down all at once.
