SIGNTIME
you said $130 ... I would be at $300 maybe you ment $130 per window. Like others have said cut out the same lettering in white with .25" - .5" offset and apply to the inside of window. The install of the lettering looks good as far as no wrinkles or bubbles visible, did you do it dry or wet? I suggest learning to install dry asap it makes everything faster and will make you better at installing in the long run. Oh and go through the design and layout forum on here and look at the posts until you wake up wondering how long you've been sleeping, you'll learn a lot in there.
